Ga door naar hoofdinhoud
A 10-megapixel, point-and-shoot camera developed by Canon in 2010.
Chips in lens glass
My G12 has developed small chips or scratches on the outside of the lens glass. The camera operates great, but now those chips are showing up on the pictures. Can this lens be replaced? The camera has never been dropped, and nothing has touched the lens, so it must be defect.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@albotrose yes you can. Check this video. Not an easy task and you could always consider replacing the complete lens assembly.
Looks like the G10/G11/G12 use the same lens setup. In that case this manual will help you with the tedious work on the lens. PowerShot-Optical-assembly.pdf
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Dennis R. Dean zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 19
Altijd: 1,009
