Ga door naar hoofdinhoud
Quit working wont turn on
Conair bonnet hair dryer only 3 months old quit working
Is dit een goede vraag?
Score 1
1 Opmerking
My Conair hair dryer stopped working, should I send it back to the company
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Suzy Cory, Try another known working outlet. If no go, more then likely has a one year warranty on hair dryer and you may want to consider contacting the manufacturer for repair/replacement/refund. If not you could disassemble the hair dryer and test/check all connections, cord/plug, switch, if fused check, with a DVOM to see if faulty. Below is a guide to disassemble various models that may help. If not wanting to work on the dryer yourself perhaps have a good local small electronics shop have a look, diagnose and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Hair Dryer
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Looks like we were answering this at the same time.
door
mayer, yes, been a while since it had happen :-)
door
Het nuttigste antwoord
It is covered under warranty. First try returning it to place of purchase.
That failing, register it here, then request a warranty repair:
https://www.conair.com/co/101e94/product...
Score 2
If it experienced a reduction of airflow, you might have tripped the safety fuse on the heating element.
Voeg je antwoord toe
Suzy Cory zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 79
Altijd: 11,432
