Display of message that says 'change the batteries'
My camera keeps displaying a message that says 'change the batteries'. Why is this?
Is dit een goede vraag?
Krijg snel toegang tot handleidingen, onderdelen en antwoorden voor jouw apparaten
@tyiilliamani, Kenzo , Ensure that the battery contacts are clean and install a new quality set of fully charged batteries and if using rechargeable's have charger tested or try another known good working compatible charger to rule it out as an issue. Possible internal clock battery may be faulty (change internal CR1220 battery) or issue with bad components in camera. Find below links to showing the internal clock battery replacement and partial disassembly guide to enable checking of internal wire connections/components/etc. to check for loose, damage, burnt. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Handleiding
Moeilijkheid:
Gemiddeld
15 - 30 minutes
Handleiding
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 3,510
