Ga door naar hoofdinhoud
Canon PowerShot SX160 IS Outer Case Replacement
Wat je nodig hebt
  1. Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: stap 1, afbeelding 1 van 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: stap 1, afbeelding 2 van 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: stap 1, afbeelding 3 van 3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Outer Case Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SX160 IS Outer Case Replacement: stap 2, afbeelding 2 van 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Outer Case Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot SX160 IS Outer Case Replacement: stap 3, afbeelding 2 van 2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
Conclusie
Jamie Secretan
1.990 Reputatie
6 handleidingen geschreven
Colorado Springs, Team 2-3, Panko Spring 2015 Lid van Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 Leden
Één opmerking
guide is missing removal of several screws. Four silver screws for front cover. I removed a total of 12 screws to remove covers. Guide only shows 6. Also requires disconnection of flex strip attached to front cover, from below wheel
Stewie Wewie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 27
Altijd: 1,970
