Ga door naar hoofdinhoud
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
20 Vragen Bekijk alle
Best way to change charging port?
My phone has been having a hard time charging while I hold it in my hand and it is connected to a charger. I believe it is because the port has been a bit worn from abuse, so would it be easier to replace the main board or just the port?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ok, so it would be "easier" to replace the whole logic board. But I wouldn't call that cost effective. The charger port is soldered onto the logic board. Technically it's not the worst repair. But if you don't have the tools or skills. It's gonna be difficult. You can't do this with a hair dryer. You need special tools. So either cough up the money for the logic board, or find a good local repair shop, that does board repair
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Benjamin Cunliffe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 957
