The charging plug is loose when plugging in
The power light doesn't come on without "jiggling" the cord to make the connection.
Is dit een goede vraag?
@cenglish53 , Constance, If charge port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link showing what is involved in repairing a mini USB attached to the board. The 2nd link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
Was dit antwoord nuttig?
Your port is widened. The way to fix it is to open up the kindle. Kindle 1st Generation SD Card Reader Replacement STOP AFTER STEP 4 as your in the kindle, What you then do is use something to push the connector down to make it a tighter fit. Be careful not to short out anything on the motherboard or damage the connector
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 415
1 Opmerking
The charging ports on older Kindles appear to be milspec which is a tighter specification than normal micro usb. I’ve found that cheap cables don’t work but Motorola docomo usb cables work just fine.
door Mike Hebel
