Ga door naar hoofdinhoud
This is the first e-reader produced by Amazon, sold from November 2007 to February 2009, with an easy to read screen, memory card slot reader, and the ability to shop for and download e-books, newspapers, magazines, and blogs.
The charging plug is loose when plugging in
The power light doesn't come on without "jiggling" the cord to make the connection.
Is dit een goede vraag?
1 Opmerking
The charging ports on older Kindles appear to be milspec which is a tighter specification than normal micro usb. I’ve found that cheap cables don’t work but Motorola docomo usb cables work just fine.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@cenglish53 , Constance, If charge port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link showing what is involved in repairing a mini USB attached to the board. The 2nd link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=ZWFMCIdZ...
https://www.amazon.com/StarSide-Charging...
Was dit antwoord nuttig?
Score 2
Your port is widened. The way to fix it is to open up the kindle. Kindle 1st Generation SD Card Reader Replacement STOP AFTER STEP 4 as your in the kindle, What you then do is use something to push the connector down to make it a tighter fit. Be careful not to short out anything on the motherboard or damage the connector
Score 2
Voeg je antwoord toe
Constance English zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 555
