Ga door naar hoofdinhoud
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Repair damage- help identify part needed
Have an iPad mini retina att model, while removing the digitizer for a repair a cable going to the cell antena area was severed, can someone help me identify the part needed as well as a reputable source ? See link for image https://drive.google.com/open?id=0B8JUkQ...
Update (04/12/2017)
Sorry about that, tried to post from a mobile and was unable to add a photo here is the photo, thanks for the help.
Is dit een goede vraag?
2 opmerkingen
Nicholas, you'll have to clear your link "You need permission" if you want anyone to look at it. You should consider posting your images with your question by using this guide Voeg afbeeldingen toe aan een bestaande vraag
door
Repost you picture using something different so we can give your a proper answer. Thanks
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That is the upper right antenna. You can find it here.
Follow this guide(the antenna is specifically addressed on steps 71-73)
Replace a right cellular antenna compatible with the model A1454, A1455, A1490 1st or 2nd generation iPad mini tablet. Afbeelding
Product
iPad mini & mini 2 Right Cellular Antenna
$19.99
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thanks for the quick answer and part source !
door
Voeg je antwoord toe
Nicholas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 244
