Ga door naar hoofdinhoud
The Nikon COOLPIX S9700 is one of many cameras from Nikon's COOLPIX series. It boasts a 30x optical zoom and a 1080p resolution in a slim, compact body.
Why won’t the S9700 connect the Wi-Fi to a phone?
I’m trying to connect my S9700 to another device through the WiFi Function. I’ve tried a few times now and it still will not work.
Is dit een goede vraag?
Score 3
1 Opmerking
i got it repaired at Bangalore mata electronics.pls mail them for ur service there e-mail id is mataelectronics@Gmail.con
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The Wi-Fi option has to be turned on in the setting menu in order for the Wi-Fi to work. Wi-Fi also will not work if the signal is too weak, this means you are too far from your phone. If these are of no help, try looking here: Nikon CoolPix S9700 Troubleshooting
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Matt Staubus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 3,413
