Ga door naar hoofdinhoud
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
How to repair the dvd writer?
I brought a inspiron1545 in last year.it's warrenty expired.my systems Dvd writer is not working.plz tell me the solution.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It would be very helpful to know what the problem is with the DVD writer. If the drive cannot play dvd's or write to disks then yes the drive is probably bad and can be replaced easily for a relatively cheap price. If you just cannot see the drive in my computer then it is likely that you have corrupted registry drive filters. Microsoft has released a FixIt program to alleviate this problem and can be located here. Simply download and run the program and it should help you resolve this situation.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Good answer +
door
Unfortunately the DVD writer drive cannot be fixed. The easiest way is to buy a replacement drive and replace it in your computer or buy an external DVD writer.
Voeg je antwoord toe
sairam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 4,073
