How do I stick volume buttons to the bracket
I tore the power/volume cable while replacing the screen. I purchased the new cable and finished disassembly. While trying to reassemble, I peeled the protective covering off of the cable beneath the volume and lock components. When I press them to the bracket, the buttons and switch (the last step/first step in reassembly) will not stick. They pop off when trying to stick the next one on. Is there another adhesive I can apply to get them to stick that will not damage the cable?
Is dit een goede vraag?
1 Opmerking
When using super glue, , I use a needle to stick down the tube of superglue and that way you only transfer a tiny amount of glue from the end of needle onto your cables and it keeps from getting too much glue from spreading to other parts of the cable.
door Chelle Cancain
