Ga door naar hoofdinhoud
The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
20 Vragen Bekijk alle
Cannot install on windows 10
Original Post: Epson WF-2540 printer
Cannot install Epson printer WF-2540 setup will not fully install the drivers. I have this problem on both computers. Before when I had windows 8 I had no problems, I upgraded to windows 10 cannot get printer to work. What can I do?
Is dit een goede vraag?
Score 3
3 opmerkingen
Try running in Windows 7 compatibility mode
door
In compatibility mode where you see Windows 7 or 8 remove the check mark. Restart your computer then try again. Worked for me.
door
hi...you can also get help from this post . it helped me in getting my drivers up and running. http://driverrestore.com/how-to-download...
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Boot up in Safe Mode and see if it will install. That failing,
Try the instructions here: http://www.epson.com/cgi-bin/Store/suppo...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
The web page is no longer available.
door
Mine works... I just used the add printer feature in windows and let it find the printer and load the drivers... No issues. Try it that way.
hi...the link in the answer above is not working, meanwhile you can also get help from this post . it helped me in getting my drivers up and running. http://driverrestore.com/how-to-download...
Epson have drivers for Windows 10 x64 and 32 bit (among other OS)
https://www.epson.no/support?productID=1...
I have installed it and it works on Windows 10 x64 1803.
The printer otherwise is a piece of junk. scanner ADF does not accept any paper thicker then Rizzla cigarettes paper.
But most infuriating, the printer refuses to print anything unless all 4 ink cartridges are read not empty. So if I have a new black ink installed, and only want to print in B&W or greytones the printer will refuse. This is to help me.
I will never buy Epson again.
Voeg je antwoord toe
Murven Kelley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 13,252
