Ga door naar hoofdinhoud
The HP Pavilion dv9000 series was introduced in 2006.
No sound Pavilion DV9000 (OS Vista)
I have the problem that the sound of my Pavilion DV9000 (DV9337eu) is not working. I have installed all the driver new, but there is no chance to hear anything. If i look in the settings of the sound i can see that it should works. If i connect an external speaker, i can also listen nothing. If i use the top components buttons for adjust the speaker level i hear by each using the beep. This means, the speakers are working propper. Is there an problem with the sound board? Can i change this, or is it onboard on the mainboard?
Can somebody answer me how i can solve this problem?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here is a link that worked for others. Give it a try--it might cure your problem. Good luck. Ralph
http://h30434.www3.hp.com/t5/Notebook-PC...
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
+ i had thise problem with my hp g6060eg - kicked vista out the day w7 rtm was released. (and btw - a pretty fast check for those problems are linux live cd's/pendrives, they work pretty good with standard hardware)
door
+ That same HP was my last PC. Crashed on me before 90 days.
door
Voeg je antwoord toe
Wolla zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 9,914
