Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
20 Vragen Bekijk alle
What adhesive to attach glass to frame in screen refurbs?
For the shops that do their own display refurbishments, what adhesive do you use to attach the new bezel/frame to the glass of the display? I've not come across anything that doesn't make a giant mess when trying to use the adhesive and still does a good job of attaching and doesn't start to lift once installed into a device.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
You can use b700 glue or you can use preglued frames. If you decide to use preglued frames you will need a framing machine. We will be updating more info in our blog therefurblab.com ! Ask us anything!
Was dit antwoord nuttig?
Try using hot glue. Have to be careful that it does not get into the LCD. Can get it at Walmart.
http://Delcity.dashrepairs.com
Voeg je antwoord toe
Bobby zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 242
