Ga door naar hoofdinhoud
the Dell Dimension 8300 was a high-end desktop hailing from 2003. it has socket 478 processor support and came with 4 GB of ddr2 RAM
7 Vragen Bekijk alle
Why will my PC not boot from SATA Solid State Drive
I upgraded by adding a SSD via SATA port on the motherboard. It works fine but will only boot if I also have a (redundant) operating system (Windows XP) on the original IDE drive. I can then choose to boot straight from Windows 7 on the SSD. Without the IDE drive I get a boot error something like Primary Hard Drive Not Found.
The IDE drive has now developed a fault and I want to install a new hard drive on the other SATA port rather than replace with in IDE drive.
Can anyone offer advice? DM.
Is dit een goede vraag?
Score 3
2 opmerkingen
All done and working, thanks.DM
door
cuando prendo mi pc,, me dice que no tiene dusco duro por que, si solamente lo quite para checar otra computadora y al insertalo de nuevo me aparecio que no tengo disco
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You may need to alter the system BIOS settings so the SSD is set as the boot drive. Or, you'll need to swap the data cable connections between the drives.
Download the systems manuals from here: Dimension-8300 Manuals
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
The bootloader for Windows 7 has likely been installed on the IDE drive. This allows you to boot to other OS installed on your PC. The bootloader installs on the primary drive, which sounds like thats your IDE drive. That could be why it won't boot to Windows 7 when the IDE drive is removed.
Have you tried removing the IDE drive and then doing a fresh install of Windows 7 on the SSD. You may need to access the bios settings by hitting F2 when prompted after powering on the PC. Check the hard drive settings to make sure SATA is enabled not IDE and that the SATA drive is set as the primary boot drive. This may allow you to install and boot Windows 7 on the SSD.
Score 4
Voeg je antwoord toe
Delta Mike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 3,197
