Screen has several wide and narrow lines running through it
Several light to dark lines running through the screen after start up. Faded color between them. Tried pulling the battery/rebooting but no luck. Any ideas?
Is dit een goede vraag?
Krijg snel toegang tot handleidingen, onderdelen en antwoorden voor jouw apparaten
B Noyes, not seeing what you see and just from your description, it does sound like a bad LCD. You do want to make sure that your cables are properly seated etc., but ultimately it sounds like a bad LCD to me. Hope this helps, good luck.
Was dit antwoord nuttig?
There's a connection issue with the tiny pins that connect your LCD to your motherboard.
From experience, try to determine if you need a new motheboard or LCD if you can before you start buying replacement parts.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 2,917
