Ga door naar hoofdinhoud
The EOS 6D was released in 2012 as Canon’s first consumer-level, full-frame DSLR. It comes pre-equipped with a 2.75”x2” LCD viewing screen, a GPS antenna and wifi connectivity.
Why is my HDMI Port not working?
When I try to plug my camera into my TV via the HDMI port, the connection is fuzzy, or does not work at all. Is repair necessary?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi, Geremy. First, check to make sure that your connecting cable is securely plugged in at both ends. If that does not fix the problem, try gently cleaning the ends of the HDMI cable and your camera's HDMI port with a cotton swab.
If neither of these solutions are successful, it is possible that your camera needs a new HDMI port.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Great, so how do I replace the HDMI port?
door
Hi ,
is this an expensive repair ( @ Canon ) : HDMI port replacement...?
(I'm afraid mine is damaged)
Grtz , H.
Score 1
1 Opmerking:
Did you ever find out how to replace the HDMI port on your Canon 90d? I am in need of doing this and can't find a place to tell me how or where I can take it to get done! Thank for any info!
door
Voeg je antwoord toe
Geremy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,220
