Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
20 Vragen Bekijk alle
muffled speakers because I dropped it in ice cream
I first attempted to clean the small holes with a napkin that did not work so I looked it up to find a suggestion to use an electric tooth brush it changed it slightly but not very much at all. should I try to leave it in rice over night? please answer as quickly as possible I'm terribly sorry I'm just freaking out a bit. thank you!
Is dit een goede vraag?
Score 7
4 opmerkingen
i did the same thing and im trying do use the rice method
door
Rice method won't solve the problem. You will actually have to clean the phone and clean it of liquid damage to avoid more problems in the future. It is advised to use 99% isopropyl alcohol and clean all the contact points for ribbon connectors such as front display ribbon plugs, logic board plugs and even on board components as you don't want them to burn out.
This is an off topic question to others:
- I recall seeing a thread about an iPad 2 digitizer repair a few days ago saying that they can wake up the iPad with the home button but the power button actually works when you hold it to turn it off but the power button would not wake up the iPad.
Did anyone else see this post somewhere recently? Because I was going to post a solution to it which would be the power & volume flex cable not seated properly or damaged.
door
Was in the same situation and I cleaned mine with a tiny tip makeup brush and in shortcuts water ejecting side by side
It was much better than cleaning with a toothbrush because I tried with it for atleast a day and got no results
I was so scared as I’m broke rn and it’s only been 5-6 months I brought this iPhone 15
I swapped my phone against ice cream and I was super scared that my speaker was gone I even went to the shop I brought it from and they said it would cost me around 8k to send a repair in apple center (I nearly cried)
I tried for atleast 2days cleaning it water ejecting kettle thing even with a mini fan and what not, I was so disappointed and frustrated hearing that distorted sound
Finally today when I cleaned it with a tiny makeup brush i was successful and it’s back to its original sound😭
door
One time I droped my phone in water it was fine but not that good and I left rice in it over night and it started working again
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Just put kettle on and wait till its starts steaming leave for 5sec and suck the speaker keep doing it for a few mins and boom it worked for min and mine was mint icecream
Was dit antwoord nuttig?
Score 4
5 opmerkingen:
what if there is a white spot
door
Can you be more specific, what do you mean by putting it on a kettle???
door
Something similar happened with my iPhone 8...the day I got it I dropped it on a muffin and now the left bottom speaker sounds horrible.... I would love to try out your meathod, im just not sure what you mean. pleas contact me asap, :) im really worried
door
He means put your phone over the steam for 5 seconds then suck out whatever is in it
door
I really hope this steam way works cause I sorta dropped mine in banana pudding
door
I had a similar situation to this, My new 6th gen ipod touch fell in yogurt and the speakers arr clogged but i poked the speakers eith a needle and ut worked
Score 3
The device needs to be properly treated for liquid damage. I strongly recommend powering it down and leaving it off until you address this condition. Do not rely on rice to take care of this! You can find a technique guide here. Go to the iPhone 5s device page also and review the teardown before you attempt to do anything so that you can be better informed as to whether or not this is something you are comfortable tackling. A word of advice: if you do choose to disassemble your device, be very careful of the ribbon cable for the Touch ID sensor.
Good luck to you!
If you found this helpful, please up-vote or Accept Answer.
Score 1
1 Opmerking:
thank you very much! I don't think I'm confident to do it myself but thanks for telling me what's going on!!
door
if you drop it in ice cream/pudding/chocolate ect i recommend scooping the chocolate out with a needle and then using a dry electric toothbrush and rubbing it on the speakers. it worked for me!
Score 1
Voeg je antwoord toe
abbie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 81
Altijd: 66,646
