Ga door naar hoofdinhoud
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
recover data from my dead phone
hi there
my phone is now completely dead because the motherboard it doesn't work, but I have a data on the phone my pictures, videos and sounds clip
so please is there any way I can do it to recover my data just help me
plz plz plz
Is dit een goede vraag?
Score 16
7 opmerkingen
This might have worked, but my old phone is a Galaxy S2. The software doesn't go back that far. :(
door
how will this work tho? I have broken my charging port so cant even connect it with a laptop. how can i recover my pictures?
door
galaxy core prime? What is the Android version of your device? If the texts was lost long before, it may be difficult to recover since the data would be overwritten. If it is not covered by other data, you can refer to some guides to recover the deleted texts and I have searched one tip from Google.
http://gg.gg/65nyp
Besides, if you have received mms, you may try this way to fix also but don't forget that you should stop to use the device until the data is retrieved.
door
You can recover data from dead Android phone,the Broken Android Data Recovery can help you extract data from the damaged phone, like cracked screen, water-damaged, black screen even from the bricked mobile phone.
https://tr.im/236IW
If you Nexus phone not damaged,you can directly Recover Deleted Data from Nexus 5
door
The motherboard it doesn't work, if you have the habit of backup, you can recover data from backup directly, but only can recover the latest backup data. Or you should try Eelphone Android Data Recovery . There has three ways to recover Android data, you should try the third one to retrieve your Android pictures .
door
2 commentaren meer tonen
Voeg een opmerking toe
7 Antwoorden
Gekozen oplossing
Only thing you could try and do is plug the phone to a computer with a USB Cable and see if anything pops up in the DCIM folder or other folders. That might work. If not then i'm sorry there's no other option,it's dead!
Was dit antwoord nuttig?
Score 5
3 opmerkingen:
I was been tried before but I didn't get any respond
door
If the data was not over written by new data, then you may still have a chance to recover your data from Android phone, Mobiledic Android data recover could do it, see this guide: recover data from internal memory
If the data has been covered by new data, then nobody or no software could save them, they will be gone forever.
door
I'm sorry to hear that bud,there's no other options then. There's no way around it. Next time try and back-up all your important info on a cloud or computer.
door
Het nuttigste antwoord
It is possible to recover data (pictures, videos, contacts, notes, etc.) from DEAD devices, whether they are iPhones (iOS devices in general) or Samsung phones (Android phones in general, such as Sony, LG, HTC, Motorola, etc.).
You have to take or send your dead device to people who specialize in data recovery from hand held devices. I am not talking about big/reputed data recovery companies as those are mostly specialized in recovery from failed drives, not from hand-held devices. It's a completely different science.
Also don't take them to people who do general repair or even microsoldering repair but are not experienced in data recovery. In this case the science is the same, but the approach for data is completely different in order to preserve and recover data.
We've had iPhones come to us after going to 1-2 and a few times to 3-4 different repair techs and all failed to recover data, and pronounced the devices dead and unrecoverable; and we could do it under an hour. A couple of times we even gave back working devices. So choose wisely who you should trust your device with specially when it comes to data.
Score 6
1 Opmerking:
Do u have any idea of a company or individual that has this specialty, my Sony Xperia z has the same issue, it just stopped working since then nothing.
door
Do people have a problem understanding the term 'DEAD' ?
you can connect it to the computer all day but it wont connect because it is dead.
no recovery software is gonna fix it.....
Is there a way of connecting to the S2 memory even though it is dead?
Score 3
Yes, but it will be complex. There are videos online showing how experts can physically remove the motherboard, clean it, and insert it into a special device. All of your information will be there. However it isn’t free, so decide if you really need it (its not too expensive though).
Score 2
1 Opmerking:
yes
I want to give my phone
door
Hi as i saw in youtube they take out internal memory chip and connect it through adapter and recovering the data but that you cant do it at home and also you wont have that technical knowledge so you can see some phone tech guy who can recover it from internal memory of your phone
1 Opmerking:
This is indeed a possibility for some models of smartphones, but not for iPhone/iPad.
door
the only solution is via reading emmc via jtag box
like easy-jtag
https://www.youtube.com/watch?v=N65d_DUX...
Can phone memos be retrieved as well when recovering data from the memory board? Also what about pictures/videos /audios that were moved on a SD card but then it was fully formatted and so the only option is through the phone. Can they be retrieved off of the phone even though they were moved to a different device?
Voeg je antwoord toe
alsamba zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 139,243
