Ga door naar hoofdinhoud
Reparatiehandleidingen, demontage- en Probleemoplossingsinformatie voor de tweede generatie Apple iPad met CDMA 3G-mobiel netwerk (Verizon), verkrijgbaar met 16, 32 of 64 GB opslagruimte. Bevat een dual-core processor van het type A5. Uitgebracht in maart 2011. Te herkennen aan modelnummer A1397. Voor reparaties is het gebruik van warmte en voorzichtig wrikken vereist.
dropped ipad, bent the alluminium case on the volume bottom
I've just dropped my ipad and the alluminium case bent on the volume button, i cant use the volume button and it stuck inside (volume square is frozen on the sceen). Is it possible to open the ipad and reshape the allumium case or is it too risky?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Hi Lou,
As you have probably noted, there is no screw to open the iPad 2 and in fact it make opening this iDevice much more complicate that an iPhone for example.
This is the reason why all iPad 2 guides are marked "Very difficult"!
I wouldn't say it is too risky, it depends on you, your skills and probably also your tools. If you want to make a good job you will have to use the good tools. Look at this iOpener at least!
  • If you decide to access the volume button hole from inside the rear case, the minimum require disassemble is the display. Look at this guide so you will have a better view on what you would have to do.
  • Once you will have the screen out, you will have a better view if further dis-assembly is required. Any further dis-assembly should be piece of cake after what you've done just before!
  • Also remember that you're gonna have to re-install the screen with new adhesive strips after that. (New adhesive strips available here.)
Let us know what is your decision, and good luck!
These custom cut adhesive strips attaches the front panel to the frame compatible with the A1395, A1396, A1397 model 2nd Gen iPad tablet. Afbeelding
Product
iPad 2 Adhesive Strips
$7.99
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries. Afbeelding
Product
iOpener
$24.95
iPad 2 CDMA LCD Afbeelding
Handleiding
iPad 2 CDMA LCD vervangen
Moeilijkheid:
Zeer moeilijk
40 minutes - 2 hours
iPad 2 CDMA Front Panel Adhesive Strips Afbeelding
Handleiding
iPad 2 CDMA Front Panel Adhesive Strips Replacement
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
Score 2
If the case is bent in the volume control area you can just use pliers to unbend the case. Be careful and use a cloth pad to avoid scaring the case. In my case (pun intended) the thin aluminum above the cutout part of the case was bent and Apple wanted almost as much as a new one to repair it.
Voeg je antwoord toe
Lou zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 24
Altijd: 6,111
