Ga door naar hoofdinhoud
The Roomba Red 4100 is a vacuum cleaner robot produced by iRobot that can clean a room all on its own.
12 Vragen Bekijk alle
Keeps Circling In Same Area
Keeps circling same area over and over and then stops. Battery is still charged. How do I correct this problem? Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Diane, this can be caused by dirty or defective bumper sensor as well as dirty cliff sensors. Clean the Roomba with compressed air and "slap" the front bumper. Apparently, the front bumper mechanism can get stuck with any contact with a wall etc. which will make the Roomba back up. Use these guides to work on your Roomba. Check on here for more information as well. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Did the trick thank you!
door
Voeg je antwoord toe
Diane zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 33
Altijd: 10,285
