Ga door naar hoofdinhoud
Macintosh Quadra 610 Teardown
Engels
Nederlands
Stap 18
Macintosh Quadra 610 Teardown, Internal Chassis: stap 0, afbeelding 1 van 3 Macintosh Quadra 610 Teardown, Internal Chassis: stap 0, afbeelding 2 van 3 Macintosh Quadra 610 Teardown, Internal Chassis: stap 0, afbeelding 3 van 3
Internal Chassis
  • The chassis is secured to the bottom cover by two tabs at the front of the unit, two rail and tab sets at the sides of the unit, support posts at the back of the chassis, and hidden brackets that slide into the bottom cover.
  • Step 1: Press up on one of the front tabs while lifting the support post. Step 2: Repeat this step on the other side until the internal chassis slides easily toward the back of the computer.
Vertaling hier toevoegen
