Ga door naar hoofdinhoud
Macintosh Quadra 610 Teardown
Engels
Nederlands
Stap 9
Macintosh Quadra 610 Teardown: stap 0, afbeelding 1 van 3 Macintosh Quadra 610 Teardown: stap 0, afbeelding 2 van 3 Macintosh Quadra 610 Teardown: stap 0, afbeelding 3 van 3
  • Remove the floppy drive cable from the motherboard. It may be necessary to lift up the edge of the motherboard to make it easier to remove the connector.
  • Remove the speaker cable from the motherboard.
  • Remove the LED cable from the motherboard.
  • Make sure to pull only on the connector, and not the wires, or you will risk damage to the connection.
  • If you have a CD-ROM drive installed in the Mac, remove the CD-ROM audio cable from the motherboard.
Vertaling hier toevoegen
