Ga door naar hoofdinhoud
iMac G3 Model M5521 Teardown
Engels
Nederlands
Stap 13
iMac G3 Model M5521 Teardown: stap 0, afbeelding 1 van 3 iMac G3 Model M5521 Teardown: stap 0, afbeelding 2 van 3 iMac G3 Model M5521 Teardown: stap 0, afbeelding 3 van 3
  • Remove the six screws on the logic board and five screws on the downconverter board.
  • The two screws located at the top of the down converter board(near the speaker) are larger screws than the other screws (with washers).
  • Gently lift the downconverter board and logic board out of the computer.
  • Using a flathead screwdriver, pry the plastic rivet off the board. Put the top half of the rivet back into the bottom half so it doesn’t get lost.
Vertaling hier toevoegen
