Ga door naar hoofdinhoud
Magic Trackpad 2 Teardown
Stap 11 vertalen
Engels
Nederlands
Stap 11
Magic Trackpad 2 Teardown: stap 0, afbeelding 1 van 2 Magic Trackpad 2 Teardown: stap 0, afbeelding 2 van 2
  • The Magic Trackpad 2 Repairability Score: 3 out of 10 (10 is easiest to repair)
  • The Lightning port and battery can be replaced independently of the logic board—if you can get the device open.
  • Replacing a damaged trackpad surface means cutting and reapplying the adhesive on the spring tabs.
  • Excessive use of strong adhesive makes it very difficult to remove the rear panel, hindering access to every internal component.
  • Without a service manual, it is difficult to open the trackpad without damaging internal components such as the battery and Taptic Engine.
Vertaling hier toevoegen
