Ga door naar hoofdinhoud
iPod Touch 6th Generation Teardown
Stap 13 vertalen
Engels
Nederlands
Stap 13
iPod Touch 6th Generation Teardown: stap 0, afbeelding 1 van 3 iPod Touch 6th Generation Teardown: stap 0, afbeelding 2 van 3 iPod Touch 6th Generation Teardown: stap 0, afbeelding 3 van 3
  • iPod turtle Touch 6th Generation Repairability Score: 4 out of 10 (10 is easiest to repair)
  • While very difficult, opening the case and replacing components is not impossible.
  • The battery is adhered with pull tabs that should aid in battery replacement.
  • Many components are soldered together, requiring either a very difficult or a very expensive repair if any one part breaks.
  • There are no external screws. Instead, a combo of clips and adhesive makes it difficult to open the case.
  • Ribbon cables connected to the logic board run over the top and connect on the bottom, making it difficult to remove the board or disconnect the cables.
  • And of course, a big high-five to our pals at Creative Electron for their awesome images and expertise!
Vertaling hier toevoegen
