Stap 14 vertalen
Stap 14
iPod Nano 6th Generation Repairability: 5 out of 10 (10 is easiest to repair)
Good: The ribbon cable connectors make it easy to disconnect the display and headphone jack from the logic board.
Good: Once the display is removed, the rest of the disassembly is relatively straightforward.
Bad: Removing the display is very difficult without using a heat gun.
Bad: The battery is soldered to the logic board, making replacement more cumbersome than necessary.
