Ga door naar hoofdinhoud
Sonos Play 5 Teardown
Stap 3 vertalen
Engels
Nederlands
Stap 3
Sonos Play 5 Teardown, Step 3 - Remove the 12 philips screws to release the Speaker panel from the case: stap 0, afbeelding 1 van 1
  • Of the 8 screws securing the speakers to the casing, two are hidden behind thick rubber bungs, which need to be removed.
  • There are also a number of smaller philips screws underneath felt-like padding on the base of the unit. These also need to be removed.
  • Much of the circuitry is covered in some sort of epoxy resin, making maintenance virtually impossible
Vertaling hier toevoegen
