Ga door naar hoofdinhoud
Mac Mini M2 Teardown
Engels
Nederlands
Stap 4
Mac Mini M2 Teardown: stap 0, afbeelding 1 van 3 Mac Mini M2 Teardown: stap 0, afbeelding 2 van 3 Mac Mini M2 Teardown: stap 0, afbeelding 3 van 3
  • With the cover removed, we can see the antenna plate. This is held down with six Torx T6 security screws, which can be removed with the appropriate screwdriver.
  • Carefully moving the plate to the side, we get just enough space to expose the antenna coaxial cable held down with a grounding clip and another T6 screw.
  • With the screw removed, a Spudger can be used to dislodge the antenna plate. Alternatively you can use an Opening Tool for this.
Vertaling hier toevoegen
