Ga door naar hoofdinhoud
iPod Touch 5th Generation Teardown
Engels
Nederlands
Stap 10
iPod Touch 5th Generation Teardown: stap 0, afbeelding 1 van 3 iPod Touch 5th Generation Teardown: stap 0, afbeelding 2 van 3 iPod Touch 5th Generation Teardown: stap 0, afbeelding 3 van 3
  • Getting at the slew of connectors on the back side of the logic board requires a little bit of careful navigation on our part and flexibility on the iPod's part.
  • No iPods were harmed in the making of this teardown. Unfortunately, we needed to pull off the soldered battery connections before we could tilt the logic board up to peek underneath.
  • A plastic opening tool makes quick work of disconnecting the various connectors on the logic board.
  • Unfortunately, we can't remove the logic board just yet. There is a ribbon cable routed underneath the battery that seems to lead to the lightning connector.
Vertaling hier toevoegen
