Inleiding
Ga naar stap 1Palm's Tungsten W (i710) is a fine PDA, a good data communicator, and a handy Web device that can also be used as a phone. Unlike other recent convergence devices, it does the work of a PDA first, then focuses on voice communication.
Wat je nodig hebt
Using a pick, slide it carefully by the side where the SD card is inserted.
Now you can see the internals for the first time.
Don't do like me, I broke one tab 🤦♂️
Carefully, disconnect the battery connector by pulling it back.
To liberate it, just pull it.
You can see the details of the contacts.
To take out the main board, we first need to liberate the side tabs.
Start to pull it from the bottom, but don't pull it completely. Let the upper side still sitting on the device.
We can see the contact of the antena with the board.
At the other side we can see a "normal" connector for an external antenna.
Now you can understand why that black plastic cover is in the back. You can take it out and connect a more powerful external antenna.
The antenna connector is now liberated and you con take out completely the main board.
We now liberate the upper black plastic piece of the.
We start by opening the "latch" side.
Now with the hinge side.
I opted to take out both sides one by one.
You can also take out the antenna and put it aside.
The battery is held by 6 tabs. To liberate it, bend them.
You can see now the two parallel batteries this Palm has in its internals.
The screen cannot be detached from the keyboard (at least with high risks).
These tabs needs to "hug" the screen.
To reassemble the PDA, it is mainly a matter of reversing the previous steps, but with some precautions.
Put special care on the power on button. The tabs needs to be properly set.
For the battery, pay attention to the metal tabs.
Put the antenna in its place first, before doing any other assembly of the board.
Add the plastic enclosure to the board.
And finally add the upper plastic part.
