Inleiding
Microsoft hardware is having a little bit of an identity crisis. Microsoft calls this new Surface Pro "the most versatile laptop", which means that this tablet is actually a laptop (that can transform into a studio surface). Tell ya what Microsoft, we are going to reach deep inside and see if we can't help. Friends, we present to you the Surface Pro 5 self-discovery teardown!
We want to help all Microsoft devices figure out what they are made of. You can view our Surface Laptop teardown here!
Want to help us help devices? Make sure to stay informed by following us on Facebook, Instagram, or Twitter for the latest teardown news.
Wat je nodig hebt
Video overzicht
From the outside, this Surface Pro looks pretty similar to last year's model. But you know what they say, it's what's on the inside that matters:
12.3” IPS PixelSense Display with 2736 × 1824 resolution (267 PPI)
Intel Kaby Lake Core m3 (4M Cache, 2.70 GHz) up to Core i7 (4M Cache, 4.00 GHz) CPU
4 GB/8 GB/16 GB 1600 MHz DDR3L RAM
128 GB/256 GB/512 GB/1 TB of solid state storage
8 MP rear-facing 1080p camera, and 5 MP front-facing 1080p Windows Hello camera
USB 3.0 port, micro-SD slot, Mini DisplayPort, and SurfaceConnect charging port
802.11a/b/g/n/ac Wi-Fi, Bluetooth 4.1
Stacked on top of its elder sibling, the 5th gen Pro looks very nearly identical. It has the exact same ports in the exact same places, and features the same physical dimensions.
The only difference we spy is that the vents are larger—but cut in a different face of the perimeter trench, rendering them much less visible.
On the back side, Microsoft engineers show off their latest advancement in hinge technology, with a newly designed mechanism that ekes out an extra 15 degrees of range, up to a 165º angle. Fantastic.
With such a similar exterior, it's no surprise that we find an identical opening procedure. Just as in the Surface Pro 4, we apply some iOpener heat, suction up the display, and slice through the adhesive with an opening pick.
We start looking for differences and pick out a whopper—Microsoft has traded away the removable blade SSD for a little more battery real estate. There goes the sole upgradeable feature from last year's model.
Additional, less-exciting differences include a more spidery heat sink design, four-cell instead of two-cell battery, and svelte new black color scheme.
The back of the display houses a number of chips that look suspiciously similar to the N-trig modules found in the Surface Pro 4:
Microsoft X904169 06 CL1714
Microsoft X904163 01 CL1715
Macronix MX25U1635F 1.8V 16 Mb MXSMIO serial flash memory
Microsoft claims to have wholly redesigned the passive cooling, to allow both the Core m3 and Core i5 models to run 100% fanless, instead of just the m3 model like last year.
With the heat sink out of the way, we still have to remove a couple of components before the motherboard is free. It's trapped under one speaker and a sensor/camera bezel.
Now that the motherboard is out, let's have some chips:
Intel Core m3-7Y30 Processor
Samsung KUS020203M-B000 NAND flash memory
Samsung K4E8E324EB-EGCF 1 GB LPDDR3 1866 MHz DRAM (4 chips for 4 GB total)
Marvell Avastar 88W8897 802.11ac, NFC and Bluetooth SoC
Nuvoton NPCT650SBBWX trusted platform module
Winbond W25Q128FV 128M-bit Serial Flash Memory
Monolithic Power Systems MP2949A tri-loop digital multi-phase controller w/ PMBus interface and MP3376A 8-ch. WLED driver
IC Identification, pt. 2:
Monolithic Power Systems MP86901-A and MP86902-B power phase
Texas Instruments CSD87334Q3D 20 A power block
Monolithic Power Systems NB685A 12 A synchronous buck converter
Monolithic Power Systems NB679A and NB680GD 8 A synchronous buck converter
Monolithic Power Systems NB681 6 A synchronous buck converter
Texas Instruments TPS62085 3 A step-down converter
Texas Instruments TPS62140 2 A step-down converter
IC Identifications, pt. 3:
Monolithic Power Systems MP2370DGT white LED driver
Texas Instruments TPS62175 0.5 A step down converter
Texas Instruments TPS70933 150 mA LDO regulator
Texas Instruments TLV3011 comparator w/ voltage reference
ON Semiconductor CAT24C16 16 Kb serial EEPROM memory and Winbond W25X40CL 4 Mb serial NOR flash memory
Bosch Sensortec BMI160 3-axis accelerometer/gyroscope
Bosch Sensortec BMA254 accelerometer (likely)
IC Identifications, pt. 4:
Texas Instruments SN74AVC2T245 dual-supply bus transceiver
Texas Instruments TS3USB30E high-speed USB 2.0 1:2 mux/demux switch
Nexperia (formerly NXP Semiconductor) 74LVC125A 3-state quad buffer/line driver
Nexperia (formerly NXP Semiconductor) 74AUP1G32 2-input OR-gate
If we learned anything from the last Surface Pro we tore down, it's that the battery is a pain to remove, and it doesn't go back in quite the same.
So, we're gonna keep it glued in today...
This four-cell LiPo measures in at 45 Wh (7.57 V x 5940 mAh). That's a nearly 18% increase in battery capacity (and 100% increase in cell count) over the previous model.
To compare Apples to
ApplesSurfaces, the 10.5" iPad Pro we tore down last week sports a 30.8 Wh battery.
That's all folks!
All told, it’s nearly identical to its predecessor—aside from ditching the last remaining upgradable component, the modular SSD. Yeah, Microsoft impressed us—by being way worse than we expected.
For more teardown action, check out our Surface Laptop teardown!
Not much difference between the models, but that mysterious empty space under the heat sink is indeed filled with extra cooling power in the form of a fan.
- Although we like connectors, the ones present in the Surface Pro aren't standard, making display removal tricky.
- The display removal procedure is simplified by the use of thin foam adhesive and a fused display, but is still not trivial.
- Adhesive holds many components in place, including the display and battery.
- Replacement of any part requires removal of the display assembly, an easy part to damage.
- The SSD is no longer replaceable.
Laatste gedachten
Repareerbaarheidsscore
(10 is gemakkelijkst te repareren)
31 opmerkingen
You forgot to document the micro SD card reader controller and a few other less notable members of the entourage of chips. Is it still the Realtek one, the RTS5304, from the Surface Pro 4? I am curious as to if they improved that aspect at all as well.
it should be Realtek RTS5343
JJ Wu -
Can I use surface pro 4 screen replacement on the new surface pro 5/2017?
