Ga door naar hoofdinhoud
Make sure this device is unplugged before doing any work on it. Never expose the fan blades when operating the fan, as the speed the motor runs on can cause serious injury.
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Fan te repareren, gebruik onze reparatiehandleidingen.
  1. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: stap 1, afbeelding 1 van 2 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: stap 1, afbeelding 2 van 2
    • Gather the required tools: a small Phillips head screwdriver and a smart wrench.
    • Make sure the device is unplugged and fan blade is not spinning before starting.
  2. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: stap 2, afbeelding 1 van 3 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: stap 2, afbeelding 2 van 3 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: stap 2, afbeelding 3 van 3
    • Unscrew the clip-on stand that connects the fan. This can be done by hand.
    • Turn the fan so that the back is facing up and remove the screw on the upper part of the housing.
    • Remove the back casing to reveal the switch's screws on the inner part of the casing. Remove those as well.
    • The switch's settings:
    • Off (center)
    • Speed 1 (left)
    • Speed 2 (right)
  3. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: stap 3, afbeelding 1 van 2 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: stap 3, afbeelding 2 van 2
    • Turn the fan around so that the front is facing upwards. Remove the front grill by carefully popping out the edges from the plastic tabs around the enclosure.
    • Remove the fan blade by carefully forcing it off the motor shaft. It may help to use the wrench as a lever and slowly push it out.
  4. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: stap 4, afbeelding 1 van 2 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: stap 4, afbeelding 2 van 2
    • Now that the blade is removed. The motor can now be removed from the other half of the housing.
    • Remove the two screws indicated in order to take the module out of the plastic.
    • The motor is connected to the blue transformer. The yellow and white wires indicate the two power outputs for the speed of the motor's rotation.
  5. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown: stap 5, afbeelding 1 van 1
    • That's it! There isn't too much when taking this device apart.
    • Note: You can further expand on the teardown by taking apart the transformer to DC motor set-up, but it's such a simple circuit that it isn't necessary to look at it.
Justin
111 Reputatie
1 Handleiding geschreven
4 opmerkingen
Hi How do you find the replacement switch?
sadeyealso - Antwoord
the switch melted….
Hi, I was wondering where I could find a clip and base for a 6 inch fan. The fan itself works just fan. Preferably it should be an online store.
Thanks for reading.
Nova Apex - Antwoord
Is it possible to purchase a replacement blade?
Wayne - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 26
Altijd: 4,364
