Ga door naar hoofdinhoud
CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown
Engels
Nederlands
Stap 2
CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: stap 0, afbeelding 1 van 3 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: stap 0, afbeelding 2 van 3 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: stap 0, afbeelding 3 van 3
Opening the Shell
  • Unscrew the clip-on stand that connects the fan. This can be done by hand.
  • Turn the fan so that the back is facing up and remove the screw on the upper part of the housing.
  • Remove the back casing to reveal the switch's screws on the inner part of the casing. Remove those as well.
  • The switch's settings:
  • Off (center)
  • Speed 1 (left)
  • Speed 2 (right)
Vertaling hier toevoegen
