Ga door naar hoofdinhoud
We had so much fun tearing down the iPhone 5s and 5c, that we just couldn't stop. We've got the tracks laid for a teardown of Apple's new A7 processor. Head over to the station 'cause the teardown train is chuggin' along. The next stop: Science.
Lucky for us, we've got Chipworks as our steadfast engineers on this trip. We're piling on the coal for one wild ride through the internals of this lightning-fast chip.
All aboard!
Whether you're riding the rails, pulling the caboose, or tied to the tracks, hitching your wagon to iFixit on Instagram, Twitter, and Facebook will keep you on track.
Deze demontage is geen reparatiehandleiding. Om je iPhone 5s te repareren, gebruik onze reparatiehandleidingen.
  1. Apple A7 Teardown, Science with iFixit: stap 1, afbeelding 1 van 2 Apple A7 Teardown, Science with iFixit: stap 1, afbeelding 2 van 2
    • It's that time of year again. The air is crisp, the leaves are turning, the Apples are coming out. If you ask us, the best thing about fall is tearing into an Apple or two. In the spirit of the season we're headed into Apple's A7 processor.
    • It wouldn't be Apple season without our friends at Chipworks. Thanks to these bearers of good tidings, we have the inside scoop on Apple's new processor.
  2. Apple A7 Teardown: stap 2, afbeelding 1 van 2 Apple A7 Teardown: stap 2, afbeelding 2 van 2
    • What, you wanted to see the internals?
    • Don't worry, we'll get there. But first, here's the science behind the magic.
    • It's not science without a laboratory. And Chipworks has just that.
    • We've got total ion blaster envy for Chipwork's Ion Beam Etcher, or IBE.
    • Our friend IBE takes layers off a semiconducter by blasting it with atoms in an ion beam. Power. Precision. Prettydangawesome.
    Hello
    I am Masoud professional iPhone repair and maintenance solutions for all of you
    Masoud - Antwoord
  3. Apple A7 Teardown: stap 3, afbeelding 1 van 2 Apple A7 Teardown: stap 3, afbeelding 2 van 2
    • After pre-processing the chips are examined. It's best to see that your specimen is ready...
    • ...ready for the transmission electron microscope (TEM).
    • This bad boy is handy when you want to know transistor strain, gate oxide thicknesses, or crystal lattice orientation.
    • Like the ion blaster, the TEM uses the shoot-first-ask-questions-later method by blasting electrons at its prey to see just what they're made of.
    • We've had fun taking a tiny peek at Chipworks's playground, but we've got to move on before the anticipatory drool leads to a series of keyboard replacements.
  4. Apple A7 Teardown, The A7 Processor: stap 4, afbeelding 1 van 2 Apple A7 Teardown, The A7 Processor: stap 4, afbeelding 2 van 2
    • As promised by Apple, and most recently confirmed by Gizmodo via the magic of benchmark testing, the A7 provides twice the performance of the A6 processor.
    • The A7 is the first use of a 64-bit processor in a smartphone. Based on AnandTech's review, it seems that the bulk of the A7's performance gains do not come from any advantages inherent to a 64-bit architecture, but rather from the switch from the outdated ARMv7 instruction set to the newly-designed ARMv8.
    • The modern ARMv8 instruction set was designed for a 64-bit architecture. It does away with the legacy support of the last 20 years, which increases efficiency, improving performance without sacrificing battery life.
  5. Apple A7 Teardown: stap 5, afbeelding 1 van 1
    • With the help of fancy, expensive equipment, Chipworks produced a die photograph of the A7. It looks a lot like its predecessor, the A6.
    • Early on, our good friends at Chipworks had this to say about the A7:
    • “We have confirmed through early analysis that the device is fabricated at Samsung’s Foundry. We suspect we will see Samsung's 28 nm Hi K metal Gate (HKMG) being used."
    • You'd think they'd just stop at the die and call it good, amirite?
    • Amiwrong.
  6. Apple A7 Teardown: stap 6, afbeelding 1 van 2 Apple A7 Teardown: stap 6, afbeelding 2 van 2
    • Check out the A7 processor's cross-section. Every little hump (through which you see that yellow line) is a transistor. By measuring the total distance between ten of these transistors, we can estimate a chip’s manufacturing process—essentially how tightly the manufacturer can pack in all that processing power.
    • The techs at Chipworks took out their [nano]meter stick and measured the distance between these transistors, which at first seemed very similar to the A6.
    • But wait! It turns out that the A7′s “gate pitch” — the distance between each transistor — is 114 nm, compared to the A6′s 123 nm.
    • Those 9 nm are a big deal. Looking to improve on their current 32 nm process, Apple decided to make the A7 with the same 28 nm process as the eight-core Samsung Exynos 5410, the current flagship CPU for Samsung’s own Galaxy line.
    • So what does that translate to? Applying some mathematrickery (28^2 divided by 32^2 = 784/1024), this seemingly small change equates to having the same computing power, but in 77% of the original area. And given that the A7 processor is larger in area than the A6, that means even more processing power to lead a healthy, smartphone-laden lifestyle.
  7. Apple A7 Teardown: stap 7, afbeelding 1 van 2 Apple A7 Teardown: stap 7, afbeelding 2 van 2
    • The A7 transistor level die photo reveals all one billion plus transistors on a 102 mm2 field.
    • No, don't bother getting out the magnifying glass, we'll up the zoom a little more for you.
    • Apple's September 10th Town Hall event marked the first time an official transistor count was given. Will we see a more transparent Apple in the future? Only time (or a back panel modification) will tell.
    • Update: Our chip-buddies have given us the "floorplan" of the A7!
  8. Apple A7 Teardown, The M7 Coprocessor: stap 8, afbeelding 1 van 2 Apple A7 Teardown, The M7 Coprocessor: stap 8, afbeelding 2 van 2
    • Chipworks did some investigatin' and found the M7 to be an NXP LPC18A1, part of the LPC1800 series of high-performing ARM Cortex-M3 based microcontrollers.
    • Don't believe them? Check out the NXP inscription in the top right of the die photo.
    • This isn't the first time we've seen a Cortex-M3 used for motion tracking. The folks who made the Oculus Rift used it for the same purpose.
    • From Chipworks: "The M7 is a new direction for Apple: in an effort to reduce power consumption, the M7 chip is dedicated to collecting and processing accelerometer, gyroscope and compass data."
  9. Apple A7 Teardown: stap 9, afbeelding 1 van 2 Apple A7 Teardown: stap 9, afbeelding 2 van 2
    • So the M7 is tasked with accessing information from three sensors, and with Chipworks' help we found these too:
    • Bosch Sensortech BMA220 3-axis accelerometer
    • STMicroelectronics 3-axis gyroscope
    • AKM AK8963 3-axis magnetometer
    • After collecting information from the accelerometer, gyroscope, and magnetometer, the M7 performs some matrix math processing magic to produce an absolute orientation of the phone relative to the world. This data is then passed to the A7 in a neat package, probably in the form of three headings (roll, pitch, and yaw).
    • Using the A7 to monitor this sort of data would be mega-overkill, so the M7 was introduced to maintain a constant, low-power watch over these sensors.
    I guess the accelerometer chip is not BMA220. If so, the accelerometer has only 6 bit information. Judging from the number on the chip, it is 330, not 220.
    tomatomato - Antwoord
  10. Apple A7 Teardown, The iSight Camera: stap 10, afbeelding 1 van 3 Apple A7 Teardown, The iSight Camera: stap 10, afbeelding 2 van 3 Apple A7 Teardown, The iSight Camera: stap 10, afbeelding 3 van 3
    • This time around, Apple opted to stick with 8 MP resolution for the iSight camera, but increased the active pixel array area by 15%. Bigger pixels and a wider f/2.2 aperture means the system delivers a 33% increase in light sensitivity.
    • That's gravy and all, but ever wonder what a 1.5 µm pixel pitch actually looks like? Well wonder no more! The first image in this step shows how your camera sees you when you take that duck-faced selfie.
    • The end result from these tweaks should be better low-light photography, and combined with the dual-color LED flash, retention of natural coloring. No more Predator-vision party pics. Well... unless you're the Predator.
  11. Apple A7 Teardown, The Wi-Fi Module: stap 11, afbeelding 1 van 1
    • Contained within this module is the BCM4334, like we saw last year in the iPhone 5. It includes IEEE 802.11 a/b/g/n single-stream MAC/baseband/radio, Bluetooth 4.0 + HS, and an integrated FM radio receiver.
    • It is designed to be used with external 2.4 GHz and 5 GHz front-end modules, which include power amplifiers, T/R switches and optional low noise amplifiers.
    • Apple chose not to upgrade the iPhone to the latest Broadcom chipset to take advantage of their new 802.11ac base stations.
  12. Apple A7 Teardown, The LTE Modem: stap 12, afbeelding 1 van 2 Apple A7 Teardown, The LTE Modem: stap 12, afbeelding 2 van 2
    • The Qualcomm MDM9615M 4G LTE modem utilizes a two-chip system: a Samsung-fabricated LTE baseband processor paired with a Samsung DRAM module to retain carrier specific information.
    • This has been quite a popular option recently as we’ve seen this IC in over a dozen smartphones this year alone.
  13. Apple A7 Teardown, RF and PA Components: stap 13, afbeelding 1 van 1
    • With all of the power of the new A7, exciting camera features, and the M7 coprocessor, it's easy to forget that smartphones are still phones, and making and taking calls ought to be a pretty high priority. This functionality is handled by an impressive array of RF components working together:
    • Skyworks SKY77810 2G/EDGE Power Amplifier
    • Avago A792503 Band 25/3 Power Amplifier
    • RF Micro RF3763 Band 5/8 Dual Power Amplifier
    • Skyworks SKY77572 Band 18/19/20 Power Amplifier
    • Skyworks SKY77496 Band 13/17 Power Amplifier
    • TriQuint TQF6414 Band 1/4 Dual Power Amplifier
    How do they find out exactly what every single chip is?
    Potato man - Antwoord
  14. Apple A7 Teardown: stap 14, afbeelding 1 van 1
    • Thanks for joining us on this tour of electronic discovery, and a big thanks again to our friends at Chipworks!
    • For the in-depth scoop, be sure to check out Chipworks' article, Inside the iPhone 5s.
    • And if you missed them last week, don't forget to check out our teardowns of the iPhone 5s and iPhone 5c, still hot and fresh from the land down under.
10 opmerkingen
Above the GPU blocks, there appears to be an sRAM block to my eyes. That's interesting, as the Wii U GPU also has that on the GPU die in addition to its larger slower eDRAM. I wonder what the performance implications are, and how big that is. I wonder if it could be used for the framebuffer for the GPU, or if it serves another function? It's too far from the CPU to seemingly be related to that. Too much latency for no reason.
tipoo - Antwoord
Maybe it's for security. XBOX 360 CPU has a sRAM block to store the hypervisor, memory encryption keys and other security stuff so the most essential security process never leave the chip. Maybe this has to do with the "secure enclave" apple talks about.
Tom Chai -
are you ppl saying that iPhone 5S has a FM radio?
gabklein - Antwoord
Actually no. FM radio chip comes with the wifi/bt chip, they are sold as one package at least since iphone 4s. But Apple has no plan to ever use it. so the pins for FM radio are simply not connected. I have the circuit schematic. solid proof
Tom Chai -
I also believe the bootrom and the device's udid are also stored it that area
Honam1021 - Antwoord
Dear All,
Is there anybody who knows the values of components located just near the Battery Connector? There are 4 passive components between Battery Connector and the metal shield of RF Part? Thanks in advance...
Hakan Canbaz - Antwoord
Hello there, what chip is taking care of the finger movement on the screen?
My screen behaves verry strange , it dous do things on itself!
Rob - Antwoord
Hello
I'm living in Iran Masoud professional iPhone repair job I'm looking for work and migration with whatever you want
Masoud - Antwoord
Hello
I am Masoud professional iPhone repair and maintenance solutions for all of you I am Vmytvanm
Masoud - Antwoord
Dear Sirs,
I need to re-ball an A7 cpu for 5s by soldering balls; which size of balls I must use?
Saadat Sadeghzadeh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 75
Altijd: 90,565
