Ga door naar hoofdinhoud
« Terug naar alle verhalen
Not so bad.
Chuck -
MacBook Pro 15" Retina Display Mid 2014
MacBook Pro 15" Retina Display Mid 2014 Display Assembly Replacement
45 minuten
Moderate
Mijn probleem
Screen cracked by closing lid on charge cord and cat stepped on it.
Mijn oplossing
My daughter wanted to do her own repair and I helped a little. The Airport card cables gave us a little trouble, but using a magnifying glass helped see that the connectors needed to be perfectly aligned to ensure fit. Bending the cables to where they needed to be helped.
The hinge was a little tricky, having to hold the two pieces and dislodge the hinge pins from the cover on the base.
Mijn advies
Bend the cables to shape and test fitment before making an attempt to actually connect. Make sure the hinges on the new screen are at the "110 degree" angle before attempting to attach, use a torx tool or metal object to move them, being careful not to touch the screen in doing so.
Use a magnet to hold all your screws in a bowl and place a magnet on your torx driver to hold the screw on the tool when reinserting and assembling (if your torx driver isn't magnetized already).
MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly Afbeelding
$319.99
1 Opmerking
The A stock screen looked new/unused.
Chuck - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 9
