Ga door naar hoofdinhoud
iMac G5 20" Model A1145 Heat Sinks Replacement
Stap 4 vertalen
Stap 4
iMac G5 20" Model A1145 Heat Sinks Replacement: stap 0, afbeelding 1 van 1
  • Lift the logic board off the heat sinks.
  • If a heat sink seems to be stuck, carefully pry it away from the logic board to separate the solidified thermal paste.
  • If you need to mount the heat sink back into the iMac, we have a thermal paste guide that makes replacing the thermal compound easy.
  • During reinstallation it is helpful to install the heat sinks one at a time, starting with the one closest to the logic board.
Vertaling hier toevoegen
