Ga door naar hoofdinhoud
iPhone X Rear Case Replacement
Wat je nodig hebt
  1. iPhone X Rear Case Replacement, SIM Card: stap 1, afbeelding 1 van 3 iPhone X Rear Case Replacement, SIM Card: stap 1, afbeelding 2 van 3 iPhone X Rear Case Replacement, SIM Card: stap 1, afbeelding 3 van 3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located near the side button on the edge of the iPhone.
    • Press firmly to eject the tray.
    Vraag FixBot
    Voeg opmerking toe
  2. iPhone X Rear Case Replacement: stap 2, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 2, afbeelding 2 van 2
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
    Vraag FixBot
    Voeg opmerking toe
  3. iPhone X Rear Case Replacement, Pentalobe Screws: stap 3, afbeelding 1 van 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • If the screws are stripped or damaged, replace the screws.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Vraag FixBot
    Voeg opmerking toe
  4. iPhone X Rear Case Replacement, Mark your opening picks: stap 4, afbeelding 1 van 3 iPhone X Rear Case Replacement, Mark your opening picks: stap 4, afbeelding 2 van 3 iPhone X Rear Case Replacement, Mark your opening picks: stap 4, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Vraag FixBot
    Voeg opmerking toe
  5. iPhone X Rear Case Replacement, Tape over any cracks: stap 5, afbeelding 1 van 3 iPhone X Rear Case Replacement, Tape over any cracks: stap 5, afbeelding 2 van 3 iPhone X Rear Case Replacement, Tape over any cracks: stap 5, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Vraag FixBot
    Voeg opmerking toe
  6. iPhone X Rear Case Replacement, Anti-Clamp instructions: stap 6, afbeelding 1 van 3 iPhone X Rear Case Replacement, Anti-Clamp instructions: stap 6, afbeelding 2 van 3 iPhone X Rear Case Replacement, Anti-Clamp instructions: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Vraag FixBot
    Voeg opmerking toe
  7. iPhone X Rear Case Replacement: stap 7, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 7, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 7, afbeelding 3 van 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Vraag FixBot
    Voeg opmerking toe
  8. iPhone X Rear Case Replacement: stap 8, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 8, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 8, afbeelding 3 van 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Vraag FixBot
    Voeg opmerking toe
  9. iPhone X Rear Case Replacement: stap 9, afbeelding 1 van 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
    • If you use a hairdryer or heat gun, do not heat to much because that can result in damaging the screen.
    Vraag FixBot
    Voeg opmerking toe
  10. iPhone X Rear Case Replacement: stap 10, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 10, afbeelding 2 van 2
    • If using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
    Vraag FixBot
    Voeg opmerking toe
  11. iPhone X Rear Case Replacement: stap 11, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 11, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 11, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel, not the screen itself.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Vraag FixBot
    Voeg opmerking toe
  12. iPhone X Rear Case Replacement: stap 12, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 12, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 12, afbeelding 3 van 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    Vraag FixBot
    Voeg opmerking toe
  13. iPhone X Rear Case Replacement, Screen information: stap 13, afbeelding 1 van 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Vraag FixBot
    Voeg opmerking toe
  14. iPhone X Rear Case Replacement: stap 14, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 14, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 14, afbeelding 3 van 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Vraag FixBot
    Voeg opmerking toe
  15. iPhone X Rear Case Replacement: stap 15, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 15, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 15, afbeelding 3 van 3
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
    Vraag FixBot
    Voeg opmerking toe
  16. iPhone X Rear Case Replacement: stap 16, afbeelding 1 van 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Vraag FixBot
    Voeg opmerking toe
  17. iPhone X Rear Case Replacement: stap 17, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 17, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 17, afbeelding 3 van 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • As pictured, make sure the frame comes off with display and doesn't get stuck in the device.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    Vraag FixBot
    Voeg opmerking toe
  18. iPhone X Rear Case Replacement, Display Assembly: stap 18, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    • Remove five Y000 screws securing the logic board connector bracket, of the following lengths:
    • Three 1.1 mm screws
    • One 3.1 mm screw
    • One 3.7 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    Vraag FixBot
    Voeg opmerking toe
  19. iPhone X Rear Case Replacement: stap 19, afbeelding 1 van 1
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Vraag FixBot
    Voeg opmerking toe
  20. iPhone X Rear Case Replacement: stap 20, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 20, afbeelding 2 van 2
    • Use the point of a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Vraag FixBot
    Voeg opmerking toe
  21. iPhone X Rear Case Replacement: stap 21, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 21, afbeelding 2 van 2
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
    Vraag FixBot
    Voeg opmerking toe
  22. iPhone X Rear Case Replacement: stap 22, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 22, afbeelding 2 van 2
    • Use the point of a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Vraag FixBot
    Voeg opmerking toe
  23. iPhone X Rear Case Replacement: stap 23, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 23, afbeelding 2 van 2
    • Use the point of a spudger to pry the digitizer cable connector up from its socket.
    • This connector's recessed location makes it tricky to reconnect. Take your time and align it carefully, then gently press it into place with your fingertip—first one side, then the other. You should feel it click into place.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    Vraag FixBot
    Voeg opmerking toe
  24. iPhone X Rear Case Replacement: stap 24, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 24, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 24, afbeelding 3 van 3
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
    Vraag FixBot
    Voeg opmerking toe
  25. iPhone X Rear Case Replacement: stap 25, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  26. iPhone X Rear Case Replacement, Lower Speaker: stap 26, afbeelding 1 van 2 iPhone X Rear Case Replacement, Lower Speaker: stap 26, afbeelding 2 van 2
    • Be careful not to touch the three rows of grounding pads near the bottom of the iPhone.
    • Remove the seven screws securing the bracket below the Taptic Engine and speaker:
    • Two Y000 1.9 mm screws
    • One Y000 1.2 mm screw
    • One Y000 1.6 mm screw
    • One Phillips 2.4 mm screw
    • One Phillips 1.7 mm screw
    • One Phillips 1.5 mm screw
    Vraag FixBot
    Voeg opmerking toe
  27. iPhone X Rear Case Replacement: stap 27, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 27, afbeelding 2 van 2
    • Lift the bracket from the edge nearest the battery. Don't try to remove it fully, as it's still connected via a small flex cable.
    Vraag FixBot
    Voeg opmerking toe
  28. iPhone X Rear Case Replacement: stap 28, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 28, afbeelding 2 van 2
    • While holding the bracket out of the way, use the point of a spudger to pry up and disconnect the flex cable underneath.
    Vraag FixBot
    Voeg opmerking toe
  29. iPhone X Rear Case Replacement: stap 29, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  30. iPhone X Rear Case Replacement: stap 30, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 30, afbeelding 2 van 2
    • Remove the 2.1 mm Y000 screw securing the speaker connector cover.
    Vraag FixBot
    Voeg opmerking toe
  31. iPhone X Rear Case Replacement: stap 31, afbeelding 1 van 1
    • Remove the speaker connector cover.
    Vraag FixBot
    Voeg opmerking toe
  32. iPhone X Rear Case Replacement: stap 32, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 32, afbeelding 2 van 2
    • Use the tip of a spudger to pry up and disconnect the speaker connector.
    Vraag FixBot
    Voeg opmerking toe
  33. iPhone X Rear Case Replacement: stap 33, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 33, afbeelding 2 van 2
    • When prying up the speaker, take care not to damage the flex cable you just disconnected. If necessary, hold it to one side so the speaker has room to come out.
    • Insert a spudger under the top edge of the speaker near the edge of the iPhone's case.
    • Gently pry up and lift the top edge of the speaker.
    • When reinstalling the speaker, check the position of the flex cable and make sure it doesn't get trapped underneath the speaker.
    Vraag FixBot
    Voeg opmerking toe
  34. iPhone X Rear Case Replacement: stap 34, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 34, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 34, afbeelding 3 van 3
    • Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
    • Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
    Vraag FixBot
    Voeg opmerking toe
  35. iPhone X Rear Case Replacement: stap 35, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 35, afbeelding 2 van 2
    • Remove the speaker.
    Vraag FixBot
    Voeg opmerking toe
  36. iPhone X Rear Case Replacement, Replace the speaker gasket: stap 36, afbeelding 1 van 3 iPhone X Rear Case Replacement, Replace the speaker gasket: stap 36, afbeelding 2 van 3 iPhone X Rear Case Replacement, Replace the speaker gasket: stap 36, afbeelding 3 van 3
    • The speaker's gasket is not reusable. During reassembly, follow this step to replace the gasket.
    • Use tweezers to peel off and remove all the old gasket from the frame and speaker.
    • Use a microfiber cloth and isopropyl alcohol to clean all the gasket's adhesive residue from the frame and speaker.
    • Before installing the speaker gasket, find its proper orientation on the bottom of the speaker—the large cutout on the gasket should go around the speaker grille mesh.
    • Remove the larger, clear liner from the gasket and use tweezers to carefully put the gasket into place on the bottom of the speaker.
    • To avoid touching the exposed adhesive, only grip the gasket by the outer edges of the liner.
    • Use your fingers or a spudger to firmly press the gasket into place to secure it with the adhesive.
    • Remove the remaining liner and put the speaker into place, making sure the speaker connector doesn't get stuck underneath.
    Vraag FixBot
    Voeg opmerking toe
  37. iPhone X Rear Case Replacement, Taptic Engine: stap 37, afbeelding 1 van 2 iPhone X Rear Case Replacement, Taptic Engine: stap 37, afbeelding 2 van 2
    • Remove the 2.3 mm Phillips screw securing the Taptic Engine.
    Vraag FixBot
    Voeg opmerking toe
  38. iPhone X Rear Case Replacement: stap 38, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 38, afbeelding 2 van 2
    • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
    Vraag FixBot
    Voeg opmerking toe
  39. iPhone X Rear Case Replacement: stap 39, afbeelding 1 van 1
    • Remove the Taptic Engine.
    Vraag FixBot
    Voeg opmerking toe
  40. iPhone X Rear Case Replacement, Battery: stap 40, afbeelding 1 van 1
    • The iPhone X's battery is secured to the rear case by four pieces of stretch-release adhesive—one on the top cell, and three on the bottom.
    • Each piece of adhesive has a black pull-tab at the end, which is lightly adhered to the side edge of the battery.
    Vraag FixBot
    Voeg opmerking toe
  41. iPhone X Rear Case Replacement: stap 41, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 41, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 41, afbeelding 3 van 3
    • Separate the first battery adhesive tab from the bottom edge of the battery.
    • Each tab has a small loop in the center; insert a tool through the loop if you're having trouble grabbing hold of the tab.
    • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    Vraag FixBot
    Voeg opmerking toe
  42. iPhone X Rear Case Replacement: stap 42, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 42, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 42, afbeelding 3 van 3
    • Repeat the above step to separate the remaining two adhesive tabs from the bottom edge of the battery.
    • Take care not to damage the speaker cable connector just below the center adhesive tab.
    Vraag FixBot
    Voeg opmerking toe
  43. iPhone X Rear Case Replacement: stap 43, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 43, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 43, afbeelding 3 van 3
    • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. This special stretch-release adhesive loses its tack when stretched and then comes out in your hand, allowing you to lift out the battery with ease.
    • If the strips break, don't panic! They don't always work as intended. Keep reading for some additional steps for removing broken strips.
    • To increase your odds of success:
    • Don't press down on the battery. Hold the iPhone firmly by its sides.
    • Keep the strips flat and unwrinkled as you pull.
    • Pull very slowly, giving the strip time to stretch and separate. It takes around 15-30 seconds of stretching to remove each strip.
    • Pull at a low angle so the strip doesn't snag along the bottom edge of the battery.
    • If a strip does break off underneath the battery and cannot be retrieved, move on to the other strips and then continue with the additional steps below.
    Vraag FixBot
    Voeg opmerking toe
  44. iPhone X Rear Case Replacement: stap 44, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 44, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 44, afbeelding 3 van 3
    • Grab one of the outer battery adhesive tabs and slowly pull it away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
    • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
    • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
    Vraag FixBot
    Voeg opmerking toe
  45. iPhone X Rear Case Replacement: stap 45, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 45, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 45, afbeelding 3 van 3
    • Repeat the previous step to remove the strip on the opposite side, leaving the center strip for last.
    Vraag FixBot
    Voeg opmerking toe
  46. iPhone X Rear Case Replacement: stap 46, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 46, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 46, afbeelding 3 van 3
    • Remove the center strip, being careful not to snag it on the speaker flex cable.
    Vraag FixBot
    Voeg opmerking toe
  47. iPhone X Rear Case Replacement: stap 47, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 47, afbeelding 2 van 2
    • The final pull tab lies very close to the Face ID hardware. If damaged, Face ID can only be repaired by Apple, so work with care.
    • Peel and separate the pull tab on the final adhesive strip, on the top edge of the upper battery cell.
    Vraag FixBot
    Voeg opmerking toe
  48. iPhone X Rear Case Replacement: stap 48, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 48, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 48, afbeelding 3 van 3
    • Pull and remove the final adhesive strip.
    • The strip may fling the battery when it separates from the iPhone, so hold your hand over the battery to secure it—but don't press down on the battery itself, or the added pressure may cause the adhesive strip to break off underneath the battery.
    • If you removed all four adhesive strips successfully, skip the next step.
    • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • Be careful not to damage the ribbon cables or the wireless charging coil directly underneath the battery.
    • For alternative methods to unstick the battery from the case, continue to the next step below.
    Vraag FixBot
    Voeg opmerking toe
  49. iPhone X Rear Case Replacement, Alternative method to unstick the battery from the case: stap 49, afbeelding 1 van 2 iPhone X Rear Case Replacement, Alternative method to unstick the battery from the case: stap 49, afbeelding 2 van 2
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
    • Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
    • Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
    • Wrap the ends of the string around a cloth (or wear gloves) to protect your fingers.
    • Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
    • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
    Vraag FixBot
    Voeg opmerking toe
  50. iPhone X Rear Case Replacement: stap 50, afbeelding 1 van 1
    • Grasp the battery from the bottom edge and remove it from the iPhone.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Reinstall the Taptic Engine and speaker before installing a new battery. This helps keep the battery aligned correctly during installation.
    • Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
    • Adhere the battery, disconnect it, and continue reassembling your device.
    • If your new battery does not come with adhesive preinstalled, refer to this guide for help replacing the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
    Vraag FixBot
    Voeg opmerking toe
  51. iPhone X Rear Case Replacement, Front Camera Assembly: stap 51, afbeelding 1 van 3 iPhone X Rear Case Replacement, Front Camera Assembly: stap 51, afbeelding 2 van 3 iPhone X Rear Case Replacement, Front Camera Assembly: stap 51, afbeelding 3 van 3
    • Using the flat end of a spudger, disconnect the three front camera assembly cables:
    • The dot projector.
    • The front camera.
    • The infrared camera.
    Vraag FixBot
    Voeg opmerking toe
  52. iPhone X Rear Case Replacement: stap 52, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 52, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 52, afbeelding 3 van 3
    • The camera cables are lightly adhered to the midframe.
    • Using the tip of a spudger, start at the connector and slide the spudger between the IR camera cable and the case to separate the cable from the case.
    • Repeat for the front camera cable.
    Vraag FixBot
    Voeg opmerking toe
  53. iPhone X Rear Case Replacement: stap 53, afbeelding 1 van 1
    • Apply heat to loosen the adhesive on the front camera assembly.
    Vraag FixBot
    Voeg opmerking toe
  54. iPhone X Rear Case Replacement: stap 54, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 54, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 54, afbeelding 3 van 3
    • Remove the front camera assembly.
    Vraag FixBot
    Voeg opmerking toe
  55. iPhone X Rear Case Replacement, Logic Board: stap 55, afbeelding 1 van 1
    • Disconnect the following cable connectors.
    • The WiFi Antenna connector.
    • The Wide-Angle Camera connector.
    • The Power Button / Flash / Microphone connector.
    • The Telephoto Camera connector.
    • The Dock Flex connector.
    • The Button / Wireless Charging connector.
    • The Cellular Antenna connector.
    Vraag FixBot
    Voeg opmerking toe
  56. iPhone X Rear Case Replacement, WiFi Antenna Connector: stap 56, afbeelding 1 van 2 iPhone X Rear Case Replacement, WiFi Antenna Connector: stap 56, afbeelding 2 van 2
    • Disconnect the WiFi Antenna cable connector.
    Vraag FixBot
    Voeg opmerking toe
  57. iPhone X Rear Case Replacement, Wide-Angle Camera Connector: stap 57, afbeelding 1 van 1
    • Disconnect the Wide-Angle Camera cable connector.
    Vraag FixBot
    Voeg opmerking toe
  58. iPhone X Rear Case Replacement, Power Button / Flash / Microphone Connector: stap 58, afbeelding 1 van 2 iPhone X Rear Case Replacement, Power Button / Flash / Microphone Connector: stap 58, afbeelding 2 van 2
    • Disconnect the Power Button / Flash / Microphone cable connector.
    Vraag FixBot
    Voeg opmerking toe
  59. iPhone X Rear Case Replacement, Telephoto Camera Connector: stap 59, afbeelding 1 van 2 iPhone X Rear Case Replacement, Telephoto Camera Connector: stap 59, afbeelding 2 van 2
    • Disconnect the Telephoto Camera cable connector.
    Vraag FixBot
    Voeg opmerking toe
  60. iPhone X Rear Case Replacement, Dock Flex Connector: stap 60, afbeelding 1 van 2 iPhone X Rear Case Replacement, Dock Flex Connector: stap 60, afbeelding 2 van 2
    • Disconnect the Dock Flex cable connector.
    • Bend the cable 90 degrees straight up to allow clearance to remove the logic board.
    Vraag FixBot
    Voeg opmerking toe
  61. iPhone X Rear Case Replacement, Button / Wireless Charging Connector: stap 61, afbeelding 1 van 2 iPhone X Rear Case Replacement, Button / Wireless Charging Connector: stap 61, afbeelding 2 van 2
    • Disconnect the Button / Wireless Charging cable connector.
    Vraag FixBot
    Voeg opmerking toe
  62. iPhone X Rear Case Replacement, Cellular Antenna Connector: stap 62, afbeelding 1 van 3 iPhone X Rear Case Replacement, Cellular Antenna Connector: stap 62, afbeelding 2 van 3 iPhone X Rear Case Replacement, Cellular Antenna Connector: stap 62, afbeelding 3 van 3
    • Disconnect the Cellular Antenna cable connector.
    • Bend the cable out of the way.
    Vraag FixBot
    Voeg opmerking toe
  63. iPhone X Rear Case Replacement: stap 63, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 63, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 63, afbeelding 3 van 3
    • The logic board cannot be removed with the SIM card tray in place. If you failed to remove it earlier, take it out now.
    • Remove the two Phillips mounting screws.
    • One 2.7 mm Phillips screw.
    • One 2.1 mm Phillips screw.
    • Remove the 2.0 mm Phillips grounding screw.
    • Remove the grounding tab.
    • Be sure to replace the metal grounding tab in the same orientation.
    Vraag FixBot
    Voeg opmerking toe
  64. iPhone X Rear Case Replacement, Retract the SIM Eject Pin: stap 64, afbeelding 1 van 1
    • When the SIM card is ejected, a pin slides out from the frame and pushes on the eject lever in the SIM card carrier. The pin needs to be pushed back into the frame so it will not block the removal of the logic board.
    Vraag FixBot
    Voeg opmerking toe
  65. iPhone X Rear Case Replacement: stap 65, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 65, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 65, afbeelding 3 van 3
    • Use a pair of fine tip tweezers to slide the SIM card eject lever toward the side of the case.
    • The eject lever should look like this when you're done. The pin will no longer block the removal of the logic board.
    Vraag FixBot
    Voeg opmerking toe
  66. iPhone X Rear Case Replacement: stap 66, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 66, afbeelding 2 van 2
    • The logic board assembly is mounted on two posts going through the lower board and are secured to the upper board. In order to remove it, you must lift it evenly straight up to clear the stand-offs.
    Vraag FixBot
    Voeg opmerking toe
  67. iPhone X Rear Case Replacement, Rear-Facing Cameras: stap 67, afbeelding 1 van 1
    • Remove two Phillips screws securing the camera bracket, of the following lengths:
    • One 2.3 mm screw
    • One 2.0 mm screw
    Vraag FixBot
    Voeg opmerking toe
  68. iPhone X Rear Case Replacement: stap 68, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 68, afbeelding 2 van 2
    • Use tweezers to gently fold the small metal grounding bracket out of the way. Do not pull up on it as it is connected to a fragile flex cable.
    Vraag FixBot
    Voeg opmerking toe
  69. iPhone X Rear Case Replacement: stap 69, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 69, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 69, afbeelding 3 van 3
    • Lift the camera bracket from the edge closest to the battery, and remove it.
    • To reinstall the camera bracket, follow the images exactly in reverse: first, lower the outside edge until the tab on the right side slots into the gap between the phone's case and the camera module. Then, hinge the bracket down over the camera module.
    Vraag FixBot
    Voeg opmerking toe
  70. iPhone X Rear Case Replacement: stap 70, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 70, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 70, afbeelding 3 van 3
    • Use an opening tool or fingernail to disconnect the two camera connectors by prying them straight up from their sockets.
    Vraag FixBot
    Voeg opmerking toe
  71. iPhone X Rear Case Replacement: stap 71, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 71, afbeelding 2 van 2
    • Press the point of a spudger against a small notch on the bottom right corner of the camera module.
    • Gently pry up to lever the camera out of the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  72. iPhone X Rear Case Replacement: stap 72, afbeelding 1 van 1
    • Remove the rear-facing camera module.
    Vraag FixBot
    Voeg opmerking toe
  73. iPhone X Rear Case Replacement, Bottom Right Screen Retainer: stap 73, afbeelding 1 van 2 iPhone X Rear Case Replacement, Bottom Right Screen Retainer: stap 73, afbeelding 2 van 2
    • Remove the 1.2 mm Y000 screw securing the cellular antenna cable to the screen retainer.
    • Bend the antenna cable away from the side of the case to allow access to the screws securing the retainer to the side of the case.
    Vraag FixBot
    Voeg opmerking toe
  74. iPhone X Rear Case Replacement: stap 74, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 74, afbeelding 2 van 2
    • Remove the three 1.5 mm Phillips screws holding the screen retainer.
    • Remove the retainer.
    Vraag FixBot
    Voeg opmerking toe
  75. iPhone X Rear Case Replacement, Lightning Connector: stap 75, afbeelding 1 van 2 iPhone X Rear Case Replacement, Lightning Connector: stap 75, afbeelding 2 van 2
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the 2.3 mm stand-off screw holding the barometric vent.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • Remove the barometric vent.
    Vraag FixBot
    Voeg opmerking toe
  76. iPhone X Rear Case Replacement: stap 76, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 76, afbeelding 2 van 2
    • Remove two 2.6 mm stand-off screws securing the Lightning connector to the back of the case.
    • Remove two 2.9 mm Phillips screws holding the charging port to the bottom of the case.
    Vraag FixBot
    Voeg opmerking toe
  77. iPhone X Rear Case Replacement: stap 77, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 77, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 77, afbeelding 3 van 3
    • To soften the adhesive holding the flex cable to the case, heat it with a hot air gun or a hair dryer, or heat the back of the case with an iOpener.
    • Peel up the dock connector cable with a spudger.
    Vraag FixBot
    Voeg opmerking toe
  78. iPhone X Rear Case Replacement: stap 78, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 78, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 78, afbeelding 3 van 3
    • Continue peeling up the dock connector.
    Vraag FixBot
    Voeg opmerking toe
  79. iPhone X Rear Case Replacement: stap 79, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 79, afbeelding 2 van 2
    • Remove the dock connector.
    Vraag FixBot
    Voeg opmerking toe
  80. iPhone X Rear Case Replacement, Interconnect Cable: stap 80, afbeelding 1 van 2 iPhone X Rear Case Replacement, Interconnect Cable: stap 80, afbeelding 2 van 2
    • After removing the Lightning connector, the only thing holding the interconnect cable to the case is adhesive.
    Vraag FixBot
    Voeg opmerking toe
  81. iPhone X Rear Case Replacement: stap 81, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 81, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 81, afbeelding 3 van 3
    • Peel off the cable with a spudger.
    Vraag FixBot
    Voeg opmerking toe
  82. iPhone X Rear Case Replacement: stap 82, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 82, afbeelding 2 van 2
    • Remove the interconnect cable.
    Vraag FixBot
    Voeg opmerking toe
  83. iPhone X Rear Case Replacement, Upper Right Screen Retainer: stap 83, afbeelding 1 van 3 iPhone X Rear Case Replacement, Upper Right Screen Retainer: stap 83, afbeelding 2 van 3 iPhone X Rear Case Replacement, Upper Right Screen Retainer: stap 83, afbeelding 3 van 3
    • Peel up the end of the dock connector to clear access to the power button and screen retainer.
    • Bend the dock connector up and out of the way.
    Vraag FixBot
    Voeg opmerking toe
  84. iPhone X Rear Case Replacement: stap 84, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 84, afbeelding 2 van 2
    • Remove the two screws holding the screen retaining clip.
    • One 1.9 mm Phillips screw.
    • Remove the screen retainer.
    • When reassembling the retainer, be sure to slide it behind the black plastic piece on the end opposite the power button.
    Vraag FixBot
    Voeg opmerking toe
  85. iPhone X Rear Case Replacement, Power Button and Flash Cable: stap 85, afbeelding 1 van 1
    • Remove the remaining 2.0 mm Phillips screw securing the power button.
    Vraag FixBot
    Voeg opmerking toe
  86. iPhone X Rear Case Replacement: stap 86, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 86, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 86, afbeelding 3 van 3
    • Peel the flex cable from the frame.
    Vraag FixBot
    Voeg opmerking toe
  87. iPhone X Rear Case Replacement: stap 87, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 87, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 87, afbeelding 3 van 3
    • With a spudger, pry out the flash and microphone.
    • Remove the assembly.
    Vraag FixBot
    Voeg opmerking toe
  88. iPhone X Rear Case Replacement, Volume Button Assembly: stap 88, afbeelding 1 van 2 iPhone X Rear Case Replacement, Volume Button Assembly: stap 88, afbeelding 2 van 2
    • Remove the 1.4 mm Phillips screw holding the grounding tab.
    • Note the orientation of the tab and be sure to place it correctly during reassembly.
    Vraag FixBot
    Voeg opmerking toe
  89. iPhone X Rear Case Replacement: stap 89, afbeelding 1 van 1
    • Remove the six screws securing the buttons.
    • Two 1.5 mm Phillips.
    • Two 1.9 mm Phillips.
    • One 2.4 mm Phillips.
    • One 1.7 mm Phillips.
    Vraag FixBot
    Voeg opmerking toe
  90. iPhone X Rear Case Replacement: stap 90, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 90, afbeelding 2 van 2
    • Disengage the ring/silent switch from the side of the case.
    • Use a spudger to peel the flex cable from the bottom of the case.
    Vraag FixBot
    Voeg opmerking toe
  91. iPhone X Rear Case Replacement: stap 91, afbeelding 1 van 1
    • Heating the case with an iOpener or the cable with a hot air gun or hair dryer will help soften the adhesive and make it easier to remove.
    • Peel off the button cable.
    • If you are planning on reusing the button / charging coil assembly, use extreme care when removing this cable. It is extremely thin and very fragile. Work slowly and carefully and put as little stress on the cable as possible.
    • Hold on to the cable with tweezers while lifting and sliding the spudger between the cable and the case.
    Vraag FixBot
    Voeg opmerking toe
  92. iPhone X Rear Case Replacement, Charging Pad / Volume Button Assembly: stap 92, afbeelding 1 van 3 iPhone X Rear Case Replacement, Charging Pad / Volume Button Assembly: stap 92, afbeelding 2 van 3 iPhone X Rear Case Replacement, Charging Pad / Volume Button Assembly: stap 92, afbeelding 3 van 3
    • Heat the back of the phone with an iOpener or the coil with a hot air gun or hair dryer to soften the adhesive and make it easier to remove.
    • Peel off the wireless charging coil.
    Vraag FixBot
    Voeg opmerking toe
  93. iPhone X Rear Case Replacement: stap 93, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 93, afbeelding 2 van 2
    Vraag FixBot
    Voeg opmerking toe
  94. iPhone X Rear Case Replacement, Move the Ring/Silent Switch: stap 94, afbeelding 1 van 1
    • If you are replacing the button assembly, you will need to transfer the ring/silent switch from the old assembly to the new one.
    • See the iPhone X Power and Audio Exterior Buttons guide for instructions on how to remove the exterior switch from the button assembly.
    Vraag FixBot
    Voeg opmerking toe
  95. iPhone X Rear Case Replacement, WiFi Antenna: stap 95, afbeelding 1 van 2 iPhone X Rear Case Replacement, WiFi Antenna: stap 95, afbeelding 2 van 2
    • Remove the 1.4 mm Phillips screw holding the first grounding tab.
    Vraag FixBot
    Voeg opmerking toe
  96. iPhone X Rear Case Replacement: stap 96, afbeelding 1 van 1
    • Remove four 1.5 mm Phillips screws.
    Vraag FixBot
    Voeg opmerking toe
  97. iPhone X Rear Case Replacement: stap 97, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 97, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 97, afbeelding 3 van 3
    • Remove two 1.1 mm Y000 screws.
    • Remove the two grounding tabs.
    • Note the orientation of the tabs and be sure to place them correctly during reassembly.
    Vraag FixBot
    Voeg opmerking toe
  98. iPhone X Rear Case Replacement: stap 98, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 98, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 98, afbeelding 3 van 3
    • Heat the back of the case with an iOpener, or the WiFi antenna with a hot air gun or hair dryer.
    • Peel the WiFi antenna from the case with a spudger.
    Vraag FixBot
    Voeg opmerking toe
  99. iPhone X Rear Case Replacement: stap 99, afbeelding 1 van 2 iPhone X Rear Case Replacement: stap 99, afbeelding 2 van 2
    • Remove the WiFi antenna.
    Vraag FixBot
    Voeg opmerking toe
  100. iPhone X Rear Case Replacement, Bluetooth Antenna: stap 100, afbeelding 1 van 2 iPhone X Rear Case Replacement, Bluetooth Antenna: stap 100, afbeelding 2 van 2
    • Remove the 2.3 mm Phillips screw securing the antenna to the rear camera frame.
    • Remove the 1.5 mm Phillips screw securing the antenna to the case.
    Vraag FixBot
    Voeg opmerking toe
  101. iPhone X Rear Case Replacement: stap 101, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 101, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 101, afbeelding 3 van 3
    • Lift the end of the cable off the post on the back of the case.
    • Peel the cable from the rear camera housing with a spudger.
    • Remove the bluetooth antenna.
    Vraag FixBot
    Voeg opmerking toe
  102. iPhone X Rear Case Replacement, Front Panel Screen Retainers: stap 102, afbeelding 1 van 3 iPhone X Rear Case Replacement, Front Panel Screen Retainers: stap 102, afbeelding 2 van 3 iPhone X Rear Case Replacement, Front Panel Screen Retainers: stap 102, afbeelding 3 van 3
    • Remove the four 1.5 mm Phillips screws holding the two left side screen retainer clips.
    • Remove the two retainers.
    Vraag FixBot
    Voeg opmerking toe
  103. iPhone X Rear Case Replacement, Remove the Ring/Silent Switch: stap 103, afbeelding 1 van 2 iPhone X Rear Case Replacement, Remove the Ring/Silent Switch: stap 103, afbeelding 2 van 2
    • Flip the switch to the left.
    • Grasp the upper arm of the switch with fine tip tweezers and slide it down to clear the retainer.
    • Lift the end up and slide it out from the other side.
    • On reassembly, the orange stripe should be on the top side as pictured here.
    Vraag FixBot
    Voeg opmerking toe
  104. iPhone X Rear Case Replacement, Remove the Button Spring Clips: stap 104, afbeelding 1 van 2 iPhone X Rear Case Replacement, Remove the Button Spring Clips: stap 104, afbeelding 2 van 2
    • Before you start trying to take these apart, go watch this video mentioned in the introduction. Removing these buttons is tricky and frustrating, so study the video carefully and try and follow iPhoneRepairGirl's instructions as exactly as you can.
    • While removing the spring clips and retainers, it is helpful to keep a finger on the outside of the button to keep it as far inside the frame as possible.
    • Flip the spring clip up 90 degrees.
    Vraag FixBot
    Voeg opmerking toe
  105. iPhone X Rear Case Replacement: stap 105, afbeelding 1 van 3 iPhone X Rear Case Replacement: stap 105, afbeelding 2 van 3 iPhone X Rear Case Replacement: stap 105, afbeelding 3 van 3
    • Grasp one end of the spring clip with a pair of tweezers.
    • Firmly pull on the end of the clip until it is free of the button.
    • Swing the clip out slightly from the button.
    • Slide the clip back the opposite direction to free the other end.
    • Remove the spring clip.
    • Repeat for the volume up and down buttons.
    Vraag FixBot
    Voeg opmerking toe
  106. iPhone X Rear Case Replacement, Remove the Button Retaining Plate: stap 106, afbeelding 1 van 3 iPhone X Rear Case Replacement, Remove the Button Retaining Plate: stap 106, afbeelding 2 van 3 iPhone X Rear Case Replacement, Remove the Button Retaining Plate: stap 106, afbeelding 3 van 3
    • Pry the right side of the retainer up about 20 degrees.
    • Pull the retainer straight out away from the button.
    • Rinse and repeat.
    • When reassembling the retainers, make sure the retainer is all the way down; the gap at the bottom should be even across the length of the button.
    Vraag FixBot
    Voeg opmerking toe
  107. iPhone X Rear Case Replacement, Remove the Volume and Power Buttons: stap 107, afbeelding 1 van 3 iPhone X Rear Case Replacement, Remove the Volume and Power Buttons: stap 107, afbeelding 2 van 3 iPhone X Rear Case Replacement, Remove the Volume and Power Buttons: stap 107, afbeelding 3 van 3
    • If you can't get hold of the button from the outside of the case, push the pins out from the inside.
    • Remove the button.
    • Repeat for the remaining buttons.
    • Before attempting to reassemble the buttons, go watch the video again. If you thought it was a pain to take them apart, wait until you try to put them back together. Be patient and work carefully and they'll eventually fit.
    Vraag FixBot
    Voeg opmerking toe
  108. iPhone X Rear Case Replacement, Rear Case: stap 108, afbeelding 1 van 1
    • The case has been stripped completely of all parts. You can now replace them into a new case.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
13 andere personen hebben deze handleiding voltooid.
Jerry Wheeler
98.191 Reputatie
92 handleidingen geschreven
1Gids Commentaar
I was able to get through the guide in both directions, but there are a few ways that the steps are pictured or worded that made reassembly confusing. I am still new to this as this is my first repair (I can't believe I started with such a challenging one!) so I am not sure what I am allowed to edit for the pictures and guide step text, so for now I have started by just leaving some comments on what did not make sense to me.
Sandy Andlow - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 298
Altijd: 27,170
