Ga door naar hoofdinhoud
iPhone SE 2020 Rear Camera Replacement
Wat je nodig hebt
  1. iPhone SE 2020 Rear Camera Replacement, Remove the pentalobe screws: stap 1, afbeelding 1 van 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone SE 2020 Rear Camera Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone SE 2020 Rear Camera Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone SE 2020 Rear Camera Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone SE 2020 Rear Camera Replacement, Tape over any cracks: stap 3, afbeelding 1 van 3 iPhone SE 2020 Rear Camera Replacement, Tape over any cracks: stap 3, afbeelding 2 van 3 iPhone SE 2020 Rear Camera Replacement, Tape over any cracks: stap 3, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone SE 2020 Rear Camera Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone SE 2020 Rear Camera Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone SE 2020 Rear Camera Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone SE 2020 Rear Camera Replacement: stap 5, afbeelding 1 van 3 iPhone SE 2020 Rear Camera Replacement: stap 5, afbeelding 2 van 3 iPhone SE 2020 Rear Camera Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone SE 2020 Rear Camera Replacement: stap 6, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement: stap 6, afbeelding 2 van 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone SE 2020 Rear Camera Replacement, Heat the display: stap 7, afbeelding 1 van 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  8. iPhone SE 2020 Rear Camera Replacement, Separate the display: stap 8, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement, Separate the display: stap 8, afbeelding 2 van 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  9. iPhone SE 2020 Rear Camera Replacement: stap 9, afbeelding 1 van 3 iPhone SE 2020 Rear Camera Replacement: stap 9, afbeelding 2 van 3 iPhone SE 2020 Rear Camera Replacement: stap 9, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone SE 2020 Rear Camera Replacement: stap 10, afbeelding 1 van 3 iPhone SE 2020 Rear Camera Replacement: stap 10, afbeelding 2 van 3 iPhone SE 2020 Rear Camera Replacement: stap 10, afbeelding 3 van 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  11. iPhone SE 2020 Rear Camera Replacement, Screen information: stap 11, afbeelding 1 van 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  12. iPhone SE 2020 Rear Camera Replacement: stap 12, afbeelding 1 van 3 iPhone SE 2020 Rear Camera Replacement: stap 12, afbeelding 2 van 3 iPhone SE 2020 Rear Camera Replacement: stap 12, afbeelding 3 van 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone SE 2020 Rear Camera Replacement: stap 13, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement: stap 13, afbeelding 2 van 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  14. iPhone SE 2020 Rear Camera Replacement: stap 14, afbeelding 1 van 3 iPhone SE 2020 Rear Camera Replacement: stap 14, afbeelding 2 van 3 iPhone SE 2020 Rear Camera Replacement: stap 14, afbeelding 3 van 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  15. iPhone SE 2020 Rear Camera Replacement: stap 15, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement: stap 15, afbeelding 2 van 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  16. iPhone SE 2020 Rear Camera Replacement: stap 16, afbeelding 1 van 3 iPhone SE 2020 Rear Camera Replacement: stap 16, afbeelding 2 van 3 iPhone SE 2020 Rear Camera Replacement: stap 16, afbeelding 3 van 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    • Remove the bracket.
  17. iPhone SE 2020 Rear Camera Replacement: stap 18, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement: stap 18, afbeelding 2 van 2
    • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
    • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone SE 2020 Rear Camera Replacement, Disconnect the display and digitizer: stap 19, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement, Disconnect the display and digitizer: stap 19, afbeelding 2 van 2
    • Use the point of a spudger to pry the lower display connector out of its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  19. iPhone SE 2020 Rear Camera Replacement: stap 20, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement: stap 20, afbeelding 2 van 2
    • Use the point of a spudger to disconnect the second lower display cable.
  20. iPhone SE 2020 Rear Camera Replacement: stap 21, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement: stap 21, afbeelding 2 van 2
    • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
  21. iPhone SE 2020 Rear Camera Replacement: stap 22, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement: stap 22, afbeelding 2 van 2
    • Use the point of a spudger to disconnect the front panel sensor assembly connector.
  22. iPhone SE 2020 Rear Camera Replacement, Remove the display assembly: stap 23, afbeelding 1 van 1
  23. iPhone SE 2020 Rear Camera Replacement, Disconnect the rear camera: stap 24, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement, Disconnect the rear camera: stap 24, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm standoff screw
    • One 3.1 mm Phillips screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  24. iPhone SE 2020 Rear Camera Replacement: stap 26, afbeelding 1 van 1
    • Remove the rear-facing camera bracket.
  25. iPhone SE 2020 Rear Camera Replacement, Remove the rear camera: stap 27, afbeelding 1 van 2 iPhone SE 2020 Rear Camera Replacement, Remove the rear camera: stap 27, afbeelding 2 van 2
    • Remove the rear camera by lifting it straight up out of its recess.
Conclusie
Repair didn’t go as planned? Check out our iPhone SE 2020 Answers community for troubleshooting help.
6 andere personen hebben deze handleiding voltooid.
Adam O'Camb
181.278 Reputatie
416 handleidingen geschreven
4 opmerkingen
Two things:
First, thanx for actually showing the Iphone SE. Almost every other repair vid/instructions I found were all rehashed Iphone 8 videos, and the opening of the phone is completely different. Your instructions showed me how to do it correctly, whereas everything else I saw had me stumped.
Also: Would love to see instructions about replacing scratched or broken glass cover for this lens. I currently can’t find anything online and have had to utilize my insurance to get a new SE at a cost of $99.00.
Alan Lemire - Antwoord
can i change iPhone se 2020 camera with iPhone 8 camera as my camera lens was broken and dust went inside and now it cannot focus and its blurry while taking photos or can i just clean the inside camera module and change the lens
Reliable Sage - Antwoord
From iPhone 8 to SE (second Generation) it works. Otherwise I don't know. Had an 8 camera installed in the SE today, also because the SE camera was not focusing. Thought the work was in vain because the camera still didn't work after the exchange. Had then changed the resolution in the camera settings and made a backup to reset it. Tried the camera again after the backup and suddenly it worked correctly.
Tom -
Thank you for this perfect guide. Whit this: Piece of cake.
klatte - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 128
Afgelopen 30 dagen: 583
Altijd: 13,208
