Ga door naar hoofdinhoud
iPhone 15 Pro Max Taptic Engine Replacement
Wat je nodig hebt
    1. iPhone 15 Pro Max Taptic Engine Replacement, Prepare your phone for disassembly: stap 1, afbeelding 1 van 2 iPhone 15 Pro Max Taptic Engine Replacement, Prepare your phone for disassembly: stap 1, afbeelding 2 van 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Pro Max Taptic Engine Replacement, Tape over any cracks: stap 2, afbeelding 1 van 2 iPhone 15 Pro Max Taptic Engine Replacement, Tape over any cracks: stap 2, afbeelding 2 van 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Pro Max Taptic Engine Replacement, Mark your opening picks: stap 3, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Mark your opening picks: stap 3, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Mark your opening picks: stap 3, afbeelding 3 van 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Pro Max Taptic Engine Replacement, Remove the pentalobe screws: stap 4, afbeelding 1 van 1
      • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Pro Max Taptic Engine Replacement, Heat the bottom edge: stap 5, afbeelding 1 van 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Pro Max Taptic Engine Replacement, Insert an opening pick: stap 6, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Insert an opening pick: stap 6, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Insert an opening pick: stap 6, afbeelding 3 van 3
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Pro Max Taptic Engine Replacement, Screen information: stap 7, afbeelding 1 van 1
      • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
      • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 15 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 3 van 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 15 Pro Max Taptic Engine Replacement, Heat the right edge: stap 9, afbeelding 1 van 1
      • Heat the right edge of the screen until it's hot to the touch.
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone 15 Pro Max Taptic Engine Replacement, Position the opening pick: stap 10, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Position the opening pick: stap 10, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Position the opening pick: stap 10, afbeelding 3 van 3
      • Don't insert your pick deeper than 5 mm along the right edge.
      • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
      • Rotate your pick so the flat edge is under the screen.
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone 15 Pro Max Taptic Engine Replacement, Release the right clip: stap 11, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Release the right clip: stap 11, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Release the right clip: stap 11, afbeelding 3 van 3
      • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
      • Insert a second opening pick to the right of the first pick.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone 15 Pro Max Taptic Engine Replacement, Separate the right edge adhesive: stap 12, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the right edge adhesive: stap 12, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the right edge adhesive: stap 12, afbeelding 3 van 3
      • Slide the first pick back to the bottom right corner of the screen.
      • Slide the second pick to the top right corner of the screen to separate the adhesive.
      • Leave these picks inserted to prevent the adhesive from resealing.
      Vraag FixBot
      Voeg opmerking toe
    9. iPhone 15 Pro Max Taptic Engine Replacement, Heat the top edge: stap 13, afbeelding 1 van 1
      • Heat the top edge of the screen until it's hot to the touch.
      Vraag FixBot
      Voeg opmerking toe
    10. iPhone 15 Pro Max Taptic Engine Replacement, Separate the top edge adhesive: stap 14, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the top edge adhesive: stap 14, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the top edge adhesive: stap 14, afbeelding 3 van 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
      Vraag FixBot
      Voeg opmerking toe
    11. iPhone 15 Pro Max Taptic Engine Replacement, Heat the left edge: stap 15, afbeelding 1 van 1
      • Heat the left edge of the screen until it's hot to the touch.
      Vraag FixBot
      Voeg opmerking toe
    12. iPhone 15 Pro Max Taptic Engine Replacement, Separate the left edge adhesive: stap 16, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the left edge adhesive: stap 16, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the left edge adhesive: stap 16, afbeelding 3 van 3
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Pro Max Taptic Engine Replacement, Swing open the screen: stap 17, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Swing open the screen: stap 17, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Swing open the screen: stap 17, afbeelding 3 van 3
      • Gently swing open the screen to the left of the phone.
      • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the screen against a box or similar object so it doesn't strain the cables.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the logic board cover: stap 18, afbeelding 1 van 2 iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the logic board cover: stap 18, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      FixMat
      $36.95
      • Use a tri-point Y000 driver to remove the six screws securing the logic board cover:
      • One 2.1 mm‑long screw
      • Five 1.5 mm‑long screws
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Pro Max Taptic Engine Replacement, Remove the logic board cover: stap 19, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the logic board cover: stap 19, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the logic board cover: stap 19, afbeelding 3 van 3
      • Use tweezers or your fingers to grab and slide the logic board cover toward the bottom of the phone to clear the sensor cable.
      • Remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the battery: stap 20, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the battery: stap 20, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the battery: stap 20, afbeelding 3 van 3
      • Use the tip of an opening pick to pry up and disconnect the battery press connector.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the ambient light sensor: stap 21, afbeelding 1 van 2 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the ambient light sensor: stap 21, afbeelding 2 van 2
      • Use the point of a spudger to pry up and disconnect the ambient light sensor press connector from the top left of the logic board.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the screen: stap 22, afbeelding 1 van 2 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the screen: stap 22, afbeelding 2 van 2
      • Disconnect the screen press connector.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Pro Max Taptic Engine Replacement, Remove the screen: stap 23, afbeelding 1 van 2 iPhone 15 Pro Max Taptic Engine Replacement, Remove the screen: stap 23, afbeelding 2 van 2
      • Remove the screen.
      • During reassembly, stop here and use this guide to install new screen adhesive.
      • Be careful not to damage any of the spring contacts as you clean the frame.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the loudspeaker: stap 24, afbeelding 1 van 1
      • Use your Phillips #000 driver to remove the four screws securing the loudspeaker:
      • Three 2.1 mm screws
      • One 2.9 mm screw
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Pro Max Taptic Engine Replacement, Separate the tape: stap 25, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the tape: stap 25, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the tape: stap 25, afbeelding 3 van 3
      • A piece of tape connects the top edges of the Taptic Engine and loudspeaker.
      • Insert an opening pick under the tape in the small gap between the Taptic Engine and the loudspeaker.
      • Slide the pick toward the left edge of the phone to separate the tape from the Taptic Engine.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Pro Max Taptic Engine Replacement, Remove the loudspeaker: stap 26, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the loudspeaker: stap 26, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the loudspeaker: stap 26, afbeelding 3 van 3
      • Insert the flat end of a spudger between the right edge of the loudspeaker and the frame.
      • Pry up until you can grab the loudspeaker with your fingers.
      • Remove the loudspeaker.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the Taptic Engine: stap 27, afbeelding 1 van 2 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the Taptic Engine: stap 27, afbeelding 2 van 2
      • Use the tip of your spudger to pry up and disconnect the Taptic Engine press connector.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Pro Max Taptic Engine Replacement, Remove the grounding clip: stap 28, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the grounding clip: stap 28, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the grounding clip: stap 28, afbeelding 3 van 3
      • Remove the two screws securing the grounding clip:
      • One 1.2 mm Phillips #000 screw
      • One 1.9 mm tri-point Y000 screw
      • Use tweezers to remove the grounding clip.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the Taptic Engine: stap 29, afbeelding 1 van 1
      Standoff Screwdriver for iPhones
      $5.49
      • Remove the two screws securing the Taptic Engine:
      • One 2.9 mm Phillips #000 screw
      • One 3.8 mm standoff screw
      • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 15 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: stap 30, afbeelding 1 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: stap 30, afbeelding 2 van 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: stap 30, afbeelding 3 van 3
      • Insert the flat end of a spudger between the left edge of the Taptic Engine and the frame.
      • Pry up until you can grab the Taptic Engine with your fingers.
      • Remove the Taptic Engine.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Clay Eickemeyer
105.750 Reputatie
472 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
10 Leden
31.367 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 100
Afgelopen 30 dagen: 341
Altijd: 7,985
