Ga door naar hoofdinhoud
iPhone 15 Front Camera Assembly Replacement
Wat je nodig hebt
  1. iPhone 15 Front Camera Assembly Replacement, Prepare your phone for disassembly: stap 1, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Prepare your phone for disassembly: stap 1, afbeelding 2 van 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Front Camera Assembly Replacement, Tape over any cracks: stap 2, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Tape over any cracks: stap 2, afbeelding 2 van 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Front Camera Assembly Replacement, Mark your opening picks: stap 3, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Mark your opening picks: stap 3, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Mark your opening picks: stap 3, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Front Camera Assembly Replacement, Remove the pentalobe screws: stap 4, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Remove the pentalobe screws: stap 4, afbeelding 2 van 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Front Camera Assembly Replacement, Heat the bottom edge: stap 5, afbeelding 1 van 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Front Camera Assembly Replacement, Insert an opening pick: stap 6, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Insert an opening pick: stap 6, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Insert an opening pick: stap 6, afbeelding 3 van 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Front Camera Assembly Replacement, Back glass information: stap 7, afbeelding 1 van 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  8. iPhone 15 Front Camera Assembly Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 3 van 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Front Camera Assembly Replacement, Heat the right edge: stap 9, afbeelding 1 van 1
    • Heat the right edge of the back glass until it's hot to the touch.
  10. iPhone 15 Front Camera Assembly Replacement, Separate the bottom right corner adhesive: stap 10, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Separate the bottom right corner adhesive: stap 10, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Separate the bottom right corner adhesive: stap 10, afbeelding 3 van 3
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
    • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 15 Front Camera Assembly Replacement, Heat the left edge: stap 11, afbeelding 1 van 1
    • Heat the left edge of the back glass until it's hot to the touch.
  12. iPhone 15 Front Camera Assembly Replacement, Separate the left edge adhesive: stap 12, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Separate the left edge adhesive: stap 12, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Separate the left edge adhesive: stap 12, afbeelding 3 van 3
    • Along the left edge, don't insert your pick deeper than 5 mm.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  13. iPhone 15 Front Camera Assembly Replacement, Heat the top edge: stap 13, afbeelding 1 van 1
    • Heat the top edge of the back glass until it's hot to the touch.
  14. iPhone 15 Front Camera Assembly Replacement, Separate the top edge adhesive: stap 14, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Separate the top edge adhesive: stap 14, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Separate the top edge adhesive: stap 14, afbeelding 3 van 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  15. iPhone 15 Front Camera Assembly Replacement, Heat the top right corner: stap 15, afbeelding 1 van 1
    • Heat the top right corner of the back glass until it's hot to the touch.
  16. iPhone 15 Front Camera Assembly Replacement, Separate the top right corner adhesive: stap 16, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Separate the top right corner adhesive: stap 16, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Separate the top right corner adhesive: stap 16, afbeelding 3 van 3
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  17. iPhone 15 Front Camera Assembly Replacement, Open the back glass: stap 17, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Open the back glass: stap 17, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Open the back glass: stap 17, afbeelding 3 van 3
    • Gently lift and swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  18. iPhone 15 Front Camera Assembly Replacement, Unfasten the lower connector cover: stap 18, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  19. iPhone 15 Front Camera Assembly Replacement, Remove the lower connector cover: stap 19, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Remove the lower connector cover: stap 19, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Remove the lower connector cover: stap 19, afbeelding 3 van 3
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
  20. iPhone 15 Front Camera Assembly Replacement, Disconnect the battery: stap 20, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Disconnect the battery: stap 20, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Disconnect the battery: stap 20, afbeelding 3 van 3
    • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
    • A plus and minus sign is printed on the head of this connector.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
  21. iPhone 15 Front Camera Assembly Replacement, Unfasten the middle connector cover: stap 21, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Unfasten the middle connector cover: stap 21, afbeelding 2 van 2
    • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
  22. iPhone 15 Front Camera Assembly Replacement, Remove the cover: stap 22, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Remove the cover: stap 22, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Remove the cover: stap 22, afbeelding 3 van 3
    • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
    • Remove the cover.
  23. iPhone 15 Front Camera Assembly Replacement, Disconnect the wireless charging coil: stap 23, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Disconnect the wireless charging coil: stap 23, afbeelding 2 van 2
    • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
  24. iPhone 15 Front Camera Assembly Replacement, Remove the back glass: stap 24, afbeelding 1 van 1
    • Remove the back glass.
  25. iPhone 15 Front Camera Assembly Replacement, Remove the upper connector cover: stap 25, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Remove the upper connector cover: stap 25, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Remove the upper connector cover: stap 25, afbeelding 3 van 3
    • Use your tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the upper connector cover.
    • Remove the cover.
  26. iPhone 15 Front Camera Assembly Replacement, Disconnect the front camera and sensors: stap 26, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Disconnect the front camera and sensors: stap 26, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Disconnect the front camera and sensors: stap 26, afbeelding 3 van 3
    • Use the tip of an opening pick to pry up and disconnect the antenna, front sensors, and front camera press connectors (three connectors in total).
  27. iPhone 15 Front Camera Assembly Replacement, Remove the front camera and sensors: stap 27, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Remove the front camera and sensors: stap 27, afbeelding 2 van 2
    • Use tweezers or your fingers to pull the front camera and sensors out of their recess in the frame and remove them.
  28. iPhone 15 Front Camera Assembly Replacement, End of disassembly: stap 28, afbeelding 1 van 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  29. iPhone 15 Front Camera Assembly Replacement, Place the front camera assembly: stap 29, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Place the front camera assembly: stap 29, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Place the front camera assembly: stap 29, afbeelding 3 van 3
    • Slide the front camera assembly into its recess in the frame.
    • Press the assembly down so it lies flat.
  30. iPhone 15 Front Camera Assembly Replacement, Connect the front camera and sensors: stap 30, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Connect the front camera and sensors: stap 30, afbeelding 2 van 2
    • Use your spudger or your fingers to connect the three front camera assembly and antenna press connectors.
  31. iPhone 15 Front Camera Assembly Replacement, Install the upper connector cover: stap 31, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Install the upper connector cover: stap 31, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Install the upper connector cover: stap 31, afbeelding 3 van 3
    • Place the cover over the logic board and align its screw holes.
    • Use your tri-point Y000 driver to install the two 1.3 mm‑long screws securing the upper connector cover.
  32. iPhone 15 Front Camera Assembly Replacement, Remove the back glass adhesive: stap 32, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Remove the back glass adhesive: stap 32, afbeelding 2 van 2
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
    • Use the tweezers to pull the adhesive off of the phone.
  33. iPhone 15 Front Camera Assembly Replacement: stap 33, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement: stap 33, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement: stap 33, afbeelding 3 van 3
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
  34. iPhone 15 Front Camera Assembly Replacement, Orient the adhesive: stap 34, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Orient the adhesive: stap 34, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Orient the adhesive: stap 34, afbeelding 3 van 3
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the rear camera to make sure the adhesive is oriented correctly.
    • Your adhesive may look slightly different.
  35. iPhone 15 Front Camera Assembly Replacement, Apply the adhesive: stap 35, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Apply the adhesive: stap 35, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Apply the adhesive: stap 35, afbeelding 3 van 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
    • Hold the liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
  36. iPhone 15 Front Camera Assembly Replacement: stap 36, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement: stap 36, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement: stap 36, afbeelding 3 van 3
    • When the adhesive is aligned, use the flat end of a spudger or your finger to press it down firmly along the bottom edge.
  37. iPhone 15 Front Camera Assembly Replacement: stap 37, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement: stap 37, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement: stap 37, afbeelding 3 van 3
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
  38. iPhone 15 Front Camera Assembly Replacement, Press the adhesive into place: stap 38, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Press the adhesive into place: stap 38, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Press the adhesive into place: stap 38, afbeelding 3 van 3
    • Make sure the liner is aligned properly by checking that all spring contacts and the rear camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    • Be careful not to touch the spring contacts sticking through the pink liner.
  39. iPhone 15 Front Camera Assembly Replacement, Remove the top liner: stap 39, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Remove the top liner: stap 39, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Remove the top liner: stap 39, afbeelding 3 van 3
    • Remove the top adhesive liner.
    • Depending on your adhesive, your liner might be split into multiple parts or be a single piece.
  40. iPhone 15 Front Camera Assembly Replacement, Prop up the back glass: stap 40, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Prop up the back glass: stap 40, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Prop up the back glass: stap 40, afbeelding 3 van 3
    • Prop up the back glass along the right edge of the iPhone, using a box or similar sturdy object to support the screen.
    • Use the flat end of a spudger or your finger to connect the wireless charging coil press connector, then the battery press connector.
  41. iPhone 15 Front Camera Assembly Replacement, Place the middle connector cover: stap 41, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Place the middle connector cover: stap 41, afbeelding 2 van 2
    • Place the middle connector cover over the wireless charging coil press connector so it slightly overhangs the slot on the logic board for the bottom clip.
  42. iPhone 15 Front Camera Assembly Replacement: stap 42, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement: stap 42, afbeelding 2 van 2
    • Use your finger to press the cover down on the logic board.
    • While pressing it down, slide the cover upward so both metal clips slot into their spots in the logic board.
  43. iPhone 15 Front Camera Assembly Replacement, Place the lower connector cover: stap 43, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Place the lower connector cover: stap 43, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Place the lower connector cover: stap 43, afbeelding 3 van 3
    • Use tweezers to hook the top of the lower connector cover into its slot on the logic board.
    • Lay the lower connector cover over the press connectors.
  44. iPhone 15 Front Camera Assembly Replacement, Install the cover screws: stap 44, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Install the cover screws: stap 44, afbeelding 2 van 2
    • Use a tri-point Y000 screwdriver to install the 0.9 mm‑long screw securing the middle connector cover.
    • Use a tri-point Y000 screwdriver to install the two 1.3 mm‑long screws securing the lower connector cover.
  45. iPhone 15 Front Camera Assembly Replacement, Remove the final adhesive liners: stap 45, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Remove the final adhesive liners: stap 45, afbeelding 2 van 2
    • Use tweezers or your fingers to separate the pull tabs at the bottom of the frame, near the charging port.
  46. iPhone 15 Front Camera Assembly Replacement: stap 46, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement: stap 46, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement: stap 46, afbeelding 3 van 3
    • Remove the narrow liner covering the adhesive along the left and top edges of the frame.
  47. iPhone 15 Front Camera Assembly Replacement: stap 47, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement: stap 47, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement: stap 47, afbeelding 3 van 3
    • Hold the back glass over the phone without letting it touch the adhesive, so you can access the remaining liners along the right edge of the phone.
    • Use a pair of tweezers or your fingers to remove the remaing liners along the right edge of the phone.
  48. iPhone 15 Front Camera Assembly Replacement, Install the back glass: stap 48, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Install the back glass: stap 48, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Install the back glass: stap 48, afbeelding 3 van 3
    • Lay the back glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all the clips.
  49. iPhone 15 Front Camera Assembly Replacement, Heat the back glass: stap 49, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Heat the back glass: stap 49, afbeelding 2 van 2
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass. If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
  50. iPhone 15 Front Camera Assembly Replacement, Press the back glass: stap 50, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement, Press the back glass: stap 50, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement, Press the back glass: stap 50, afbeelding 3 van 3
    • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
  51. iPhone 15 Front Camera Assembly Replacement: stap 51, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement: stap 51, afbeelding 2 van 2
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
  52. iPhone 15 Front Camera Assembly Replacement: stap 52, afbeelding 1 van 3 iPhone 15 Front Camera Assembly Replacement: stap 52, afbeelding 2 van 3 iPhone 15 Front Camera Assembly Replacement: stap 52, afbeelding 3 van 3
    • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Stack them to a consistent height taller than the camera bump.
  53. iPhone 15 Front Camera Assembly Replacement: stap 53, afbeelding 1 van 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
  54. iPhone 15 Front Camera Assembly Replacement, Install the pentalobe screws: stap 54, afbeelding 1 van 2 iPhone 15 Front Camera Assembly Replacement, Install the pentalobe screws: stap 54, afbeelding 2 van 2
    • Use a P2 pentalobe driver to install the two 7.7 mm‑long screws on either side of the charging port.
Conclusie
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Één andere persoon heeft deze handleiding voltooid.
Clay Eickemeyer
97.143 Reputatie
470 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
10 Leden
16.028 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 119
Afgelopen 30 dagen: 414
Altijd: 5,748
