Ga door naar hoofdinhoud
iPhone 13 SIM Card Reader Replacement
Wat je nodig hebt
  1. iPhone 13 SIM Card Reader Replacement, Eject the SIM card tray: stap 1, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Eject the SIM card tray: stap 1, afbeelding 2 van 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the volume button edge of the iPhone.
    • Press firmly to eject the tray.
  2. iPhone 13 SIM Card Reader Replacement, Remove the SIM card tray: stap 2, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement, Remove the SIM card tray: stap 2, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement, Remove the SIM card tray: stap 2, afbeelding 3 van 3
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
  3. iPhone 13 SIM Card Reader Replacement, Remove the pentalobe screws: stap 3, afbeelding 1 van 1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  4. iPhone 13 SIM Card Reader Replacement, Mark your opening picks: stap 4, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement, Mark your opening picks: stap 4, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement, Mark your opening picks: stap 4, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  5. iPhone 13 SIM Card Reader Replacement, Tape over any cracks: stap 5, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement, Tape over any cracks: stap 5, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement, Tape over any cracks: stap 5, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  6. iPhone 13 SIM Card Reader Replacement, Anti-Clamp instructions: stap 6, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement, Anti-Clamp instructions: stap 6, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement, Anti-Clamp instructions: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Clamp
    $24.95
    Koop
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  7. iPhone 13 SIM Card Reader Replacement: stap 7, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement: stap 7, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement: stap 7, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  8. iPhone 13 SIM Card Reader Replacement: stap 8, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement: stap 8, afbeelding 2 van 2
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  9. iPhone 13 SIM Card Reader Replacement, Heat the bottom edge: stap 9, afbeelding 1 van 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  10. iPhone 13 SIM Card Reader Replacement, Apply a suction cup: stap 10, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Apply a suction cup: stap 10, afbeelding 2 van 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
  11. iPhone 13 SIM Card Reader Replacement, Lift the screen slightly: stap 11, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement, Lift the screen slightly: stap 11, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement, Lift the screen slightly: stap 11, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  12. iPhone 13 SIM Card Reader Replacement, Heat the right edge: stap 12, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Heat the right edge: stap 12, afbeelding 2 van 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 13 SIM Card Reader Replacement, Separate the right adhesive: stap 13, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement, Separate the right adhesive: stap 13, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement, Separate the right adhesive: stap 13, afbeelding 3 van 3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  14. iPhone 13 SIM Card Reader Replacement: stap 14, afbeelding 1 van 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 13 SIM Card Reader Replacement: stap 15, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement: stap 15, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement: stap 15, afbeelding 3 van 3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may the top sensors.
    • Leave the pick in the top left corner before continuing.
  16. iPhone 13 SIM Card Reader Replacement, Heat the left edge: stap 16, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Heat the left edge: stap 16, afbeelding 2 van 2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  17. iPhone 13 SIM Card Reader Replacement, Screen information: stap 17, afbeelding 1 van 1
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  18. iPhone 13 SIM Card Reader Replacement, Separate the left adhesive: stap 18, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Separate the left adhesive: stap 18, afbeelding 2 van 2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  19. iPhone 13 SIM Card Reader Replacement, Open the iPhone: stap 19, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement, Open the iPhone: stap 19, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement, Open the iPhone: stap 19, afbeelding 3 van 3
    • If you haven't removed your suction handle, remove it now.
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  20. iPhone 13 SIM Card Reader Replacement, Unscrew the battery and display connector cover: stap 20, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    Koop
    • Use a Phillips screwdriver to remove the three 1.3 mm screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  21. iPhone 13 SIM Card Reader Replacement, Remove the battery and display connector cover: stap 21, afbeelding 1 van 1
    • Remove the cover.
  22. iPhone 13 SIM Card Reader Replacement, Disconnect the battery: stap 22, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Disconnect the battery: stap 22, afbeelding 2 van 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  23. iPhone 13 SIM Card Reader Replacement, Disconnect the display cable: stap 23, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Disconnect the display cable: stap 23, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  24. iPhone 13 SIM Card Reader Replacement, Unscrew the front sensor connector cover: stap 24, afbeelding 1 van 1
    • Remove three screws securing the front sensor connector cover:
    • One 1.7 mm Phillips screw
    • One 1.3 mm Phillips screw
    • One 1.8 mm Y000 screw
  25. iPhone 13 SIM Card Reader Replacement, Remove the front sensor connector cover: stap 25, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Remove the front sensor connector cover: stap 25, afbeelding 2 van 2
    • Swing the cover up from the center of the phone until the small clip by the edge of the phone unhooks.
  26. iPhone 13 SIM Card Reader Replacement: stap 26, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement: stap 26, afbeelding 2 van 2
    • Remove the cover.
    • During reassembly, insert the clip on the left edge into its slot first, then hinge the rest of the cover into place.
  27. iPhone 13 SIM Card Reader Replacement, Disconnect the front sensors: stap 27, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Disconnect the front sensors: stap 27, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
  28. iPhone 13 SIM Card Reader Replacement, Remove the screen: stap 28, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Remove the screen: stap 28, afbeelding 2 van 2
  29. iPhone 13 SIM Card Reader Replacement, Unscrew the Taptic Engine: stap 29, afbeelding 1 van 1
    • Use a Phillips driver to remove the three 2.2 mm screws securing the Taptic Engine.
  30. iPhone 13 SIM Card Reader Replacement, Remove the Taptic Engine bracket: stap 30, afbeelding 1 van 1
    • Remove the Taptic Engine bracket from the top two screw hole tabs.
  31. iPhone 13 SIM Card Reader Replacement, Reposition the Taptic Engine: stap 31, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement, Reposition the Taptic Engine: stap 31, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement, Reposition the Taptic Engine: stap 31, afbeelding 3 van 3
    • Swing the Taptic Engine up from its lower edge so that it sits upside down on the SIM card reader.
    • Be careful not to tear the delicate ribbon cable connecting the Taptic Engine to the logic board. Don't pull or twist the Taptic Engine while swinging it onto the SIM card reader.
  32. iPhone 13 SIM Card Reader Replacement, Disconnect the Taptic Engine: stap 32, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Disconnect the Taptic Engine: stap 32, afbeelding 2 van 2
    • Use the point of a spudger to pry the Taptic Engine cable connector straight up and out of its socket on the logic board.
  33. iPhone 13 SIM Card Reader Replacement, Remove the Taptic Engine: stap 33, afbeelding 1 van 1
    • Remove the Taptic Engine from the iPhone.
  34. iPhone 13 SIM Card Reader Replacement, Reassembly information: stap 34, afbeelding 1 van 3 iPhone 13 SIM Card Reader Replacement, Reassembly information: stap 34, afbeelding 2 van 3 iPhone 13 SIM Card Reader Replacement, Reassembly information: stap 34, afbeelding 3 van 3
    • During reassembly, follow these steps to reconnect the Taptic Engine:
    • Place the Taptic Engine upside-down on the SIM card reader so that the Taptic Engine's ribbon cable faces its connector on the logic board.
    • Use the flat end of a spudger or the tip of your finger to reconnect the Taptic Engine press connector.
    • Flip the Taptic Engine back into its recess.
  35. iPhone 13 SIM Card Reader Replacement, Disconnect the SIM card reader: stap 35, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Disconnect the SIM card reader: stap 35, afbeelding 2 van 2
    • Use the point of a spudger to pry the SIM card reader cable connector straight up and out of its socket on the logic board.
    • The SIM card reader cable connector is located next to the battery cable connector.
  36. iPhone 13 SIM Card Reader Replacement, Unscrew the SIM card reader: stap 36, afbeelding 1 van 1
    Standoff Screwdriver for iPhones
    $5.49
    Koop
    • Remove the three screws securing the SIM card reader:
    • One 1.2 mm Phillips screw
    • Two 3.2 mm standoff screws
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  37. iPhone 13 SIM Card Reader Replacement, Move the eject pin: stap 37, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Move the eject pin: stap 37, afbeelding 2 van 2
    • The SIM card eject pin blocks the SIM card reader from being removed when it is fully extended into the phone.
    • Use the tip of a spudger to push the SIM card eject pin away from the SIM card reader into the edge of the phone.
  38. iPhone 13 SIM Card Reader Replacement, Remove the SIM card reader: stap 38, afbeelding 1 van 2 iPhone 13 SIM Card Reader Replacement, Remove the SIM card reader: stap 38, afbeelding 2 van 2
    • Remove the SIM card reader from the iPhone.
    • Before reinstallation, make sure the SIM eject pin is pushed into the edge of the phone.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Answers community for help.
6 andere personen hebben deze handleiding voltooid.
Kyle Smith
41.004 Reputatie
123 handleidingen geschreven
5 opmerkingen
Manca tutta la parte di rimozione del Taptic Engine, altrimenti non si arriva alle viti a distanziale del punto 27.
Nick - Antwoord
Hi Nick, thank you for commenting about the missing steps! I have now added the Taptic Engine removal to this guide.
Kyle Smith -
From iPhone 12 you can easily swap the reader with a dual sim reader to have dual physical sim instead of esim on board. I did personally the change and iOS recognised immediately the reader without any issue on my iPhone 13
Evic Zega - Antwoord
Done, works great with dual physical sim, ios system recognizes the new reader and gives you the menu options to manage the two sim cards
tomas Freebird - Antwoord
The SIM card reader is the same of iphone 13?
Mateus - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 30
Afgelopen 7 dagen: 130
Afgelopen 30 dagen: 569
Altijd: 11,322
