Ga door naar hoofdinhoud
iPhone 13 Rear-Facing Camera Replacement
Wat je nodig hebt
  1. iPhone 13 Rear-Facing Camera Replacement, Remove the pentalobe screws: stap 1, afbeelding 1 van 1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 13 Rear-Facing Camera Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 13 Rear-Facing Camera Replacement, Tape over any cracks: stap 3, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement, Tape over any cracks: stap 3, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement, Tape over any cracks: stap 3, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 13 Rear-Facing Camera Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 13 Rear-Facing Camera Replacement: stap 5, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement: stap 5, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 13 Rear-Facing Camera Replacement: stap 6, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement: stap 6, afbeelding 2 van 2
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 13 Rear-Facing Camera Replacement, Heat the bottom edge: stap 7, afbeelding 1 van 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 13 Rear-Facing Camera Replacement, Apply a suction cup: stap 8, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement, Apply a suction cup: stap 8, afbeelding 2 van 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
  9. iPhone 13 Rear-Facing Camera Replacement, Lift the screen slightly: stap 9, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement, Lift the screen slightly: stap 9, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement, Lift the screen slightly: stap 9, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 13 Rear-Facing Camera Replacement, Heat the right edge: stap 10, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement, Heat the right edge: stap 10, afbeelding 2 van 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  11. iPhone 13 Rear-Facing Camera Replacement, Separate the right adhesive: stap 11, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement, Separate the right adhesive: stap 11, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement, Separate the right adhesive: stap 11, afbeelding 3 van 3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  12. iPhone 13 Rear-Facing Camera Replacement: stap 12, afbeelding 1 van 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 13 Rear-Facing Camera Replacement: stap 13, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement: stap 13, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement: stap 13, afbeelding 3 van 3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may the top sensors.
    • Leave the pick in the top left corner before continuing.
  14. iPhone 13 Rear-Facing Camera Replacement, Heat the left edge: stap 14, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement, Heat the left edge: stap 14, afbeelding 2 van 2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 13 Rear-Facing Camera Replacement, Screen information: stap 15, afbeelding 1 van 1
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  16. iPhone 13 Rear-Facing Camera Replacement, Separate the left adhesive: stap 16, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement, Separate the left adhesive: stap 16, afbeelding 2 van 2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  17. iPhone 13 Rear-Facing Camera Replacement, Open the iPhone: stap 17, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement, Open the iPhone: stap 17, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement, Open the iPhone: stap 17, afbeelding 3 van 3
    • If you haven't removed your suction handle, remove it now.
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  18. iPhone 13 Rear-Facing Camera Replacement, Unscrew the battery and display connector cover: stap 18, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the three 1.3 mm screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 13 Rear-Facing Camera Replacement, Remove the battery and display connector cover: stap 19, afbeelding 1 van 1
    • Remove the cover.
  20. iPhone 13 Rear-Facing Camera Replacement, Disconnect the battery: stap 20, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement, Disconnect the battery: stap 20, afbeelding 2 van 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 13 Rear-Facing Camera Replacement, Disconnect the display cable: stap 21, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement, Disconnect the display cable: stap 21, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. iPhone 13 Rear-Facing Camera Replacement, Unscrew the front sensor connector cover: stap 22, afbeelding 1 van 1
    • Remove three screws securing the front sensor connector cover:
    • One 1.7 mm Phillips screw
    • One 1.3 mm Phillips screw
    • One 1.8 mm Y000 screw
  23. iPhone 13 Rear-Facing Camera Replacement, Remove the front sensor connector cover: stap 23, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement, Remove the front sensor connector cover: stap 23, afbeelding 2 van 2
    • Swing the cover up from the center of the phone until the small clip by the edge of the phone unhooks.
  24. iPhone 13 Rear-Facing Camera Replacement: stap 24, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement: stap 24, afbeelding 2 van 2
    • Remove the cover.
    • During reassembly, insert the clip on the left edge into its slot first, then hinge the rest of the cover into place.
  25. iPhone 13 Rear-Facing Camera Replacement, Disconnect the front sensors: stap 25, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement, Disconnect the front sensors: stap 25, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
  26. iPhone 13 Rear-Facing Camera Replacement, Remove the screen: stap 26, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement, Remove the screen: stap 26, afbeelding 2 van 2
  27. iPhone 13 Rear-Facing Camera Replacement, Unscrew the camera cover: stap 27, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the three 1.7 mm screws securing the rear-facing camera cover.
  28. iPhone 13 Rear-Facing Camera Replacement, Remove the camera cover: stap 28, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement, Remove the camera cover: stap 28, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement, Remove the camera cover: stap 28, afbeelding 3 van 3
    • Lift the camera cover from the edge opposite to the logic board, and remove it.
    • To reinstall the camera cover, first insert the tabs on the edge closest to the logic board into their slots in the phone frame. Then hinge the cover closed.
  29. iPhone 13 Rear-Facing Camera Replacement, Disconnect the camera assembly: stap 29, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement, Disconnect the camera assembly: stap 29, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the first camera cable connector by prying it straight up from its socket.
  30. iPhone 13 Rear-Facing Camera Replacement: stap 30, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement: stap 30, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the second camera cable connector by prying it straight up from its socket.
  31. iPhone 13 Rear-Facing Camera Replacement, Remove the rear-facing cameras: stap 31, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement, Remove the rear-facing cameras: stap 31, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement, Remove the rear-facing cameras: stap 31, afbeelding 3 van 3
    • Insert the tip of a spudger under the bottom left cable attached to the camera assembly and lift up slightly to dislodge the rear-facing camera assembly.
    • Use the tip of a spudger to lift the top edge of the camera assembly enough so that you can grab it with your fingers.
  32. iPhone 13 Rear-Facing Camera Replacement: stap 32, afbeelding 1 van 2 iPhone 13 Rear-Facing Camera Replacement: stap 32, afbeelding 2 van 2
    • Grab the camera assembly with your fingers to lift it out of its recess.
  33. iPhone 13 Rear-Facing Camera Replacement: stap 33, afbeelding 1 van 1
    • Remove the rear-facing cameras from the iPhone.
  34. iPhone 13 Rear-Facing Camera Replacement, Reassembly information: stap 34, afbeelding 1 van 3 iPhone 13 Rear-Facing Camera Replacement, Reassembly information: stap 34, afbeelding 2 van 3 iPhone 13 Rear-Facing Camera Replacement, Reassembly information: stap 34, afbeelding 3 van 3
    • During reassembly, insert the two camera assembly cables into the gap between the upper battery wall and lower camera wall.
    • First, insert the two camera assembly cables into the gap.
    • Then, press the rest of the camera assembly down into its recess.
Conclusie
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Answers community for help.
8 andere personen hebben deze handleiding voltooid.
Kyle Smith
44.809 Reputatie
123 handleidingen geschreven
2 opmerkingen
Habrá alguna guía para reemplazar el flash del iPhone 13 Pro? Gracias
Jesus Jasso - Antwoord
thanks! helped a lot!
Tristan Eakin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 28
Afgelopen 7 dagen: 232
Afgelopen 30 dagen: 945
Altijd: 40,423
