iMac G5 20" Model A1076 Inverter Replacement
Inleiding
Ga naar stap 1Use this guide to replace your display inverter.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
Remove the following three screws securing the inverter to the chassis:
Two 7.9 mm Phillips.
One 26 mm Phillips.
4 andere personen hebben deze handleiding voltooid.
