Ga door naar hoofdinhoud
HP Compaq 6730b Display Replacement
Engels
Nederlands
Stap 5
HP Compaq 6730b Display Replacement: stap 0, afbeelding 1 van 3 HP Compaq 6730b Display Replacement: stap 0, afbeelding 2 van 3 HP Compaq 6730b Display Replacement: stap 0, afbeelding 3 van 3
  • Lift the left and right sides of the switch cover until it detaches from the computer, but do not yet try to remove it.
  • The LED board cable is still attached, disconnect it from the Zif connector by simply pulling it out in an upward direction.
  • With both ribbon cables disconnected, remove the switch cover.
Vertaling hier toevoegen
