Ga door naar hoofdinhoud
Xbox Series X Power Supply Replacement
Wat je nodig hebt
  1. Xbox Series X Power Supply Replacement, Uncover the back panel screws: stap 1, afbeelding 1 van 2 Xbox Series X Power Supply Replacement, Uncover the back panel screws: stap 1, afbeelding 2 van 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Power Supply Replacement: stap 2, afbeelding 1 van 3 Xbox Series X Power Supply Replacement: stap 2, afbeelding 2 van 3 Xbox Series X Power Supply Replacement: stap 2, afbeelding 3 van 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    Recommend using a hair dryer to soften the label adhesive.
    Crash - Antwoord
    Microsoft can void your warranty. They can use whatever excuse if it is sent in because you opened it and you cannot prove you didn’t damage it.
    DirtyD - Antwoord
  3. Xbox Series X Power Supply Replacement, Remove the back panel screws: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Power Supply Replacement, Unclip the back panel: stap 4, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Unclip the back panel: stap 4, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Unclip the back panel: stap 4, afbeelding 3 van 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Power Supply Replacement: stap 5, afbeelding 1 van 2 Xbox Series X Power Supply Replacement: stap 5, afbeelding 2 van 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Power Supply Replacement, Remove the back panel: stap 6, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Remove the back panel: stap 6, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Remove the back panel: stap 6, afbeelding 3 van 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Power Supply Replacement: stap 7, afbeelding 1 van 3 Xbox Series X Power Supply Replacement: stap 7, afbeelding 2 van 3 Xbox Series X Power Supply Replacement: stap 7, afbeelding 3 van 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X Power Supply Replacement, Remove the fan screws: stap 8, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
    are there any 10.5mm wide head screw for the xbox fan for sale because i need a replacement because i accidentally broke mine
    GhostMindX9 - Antwoord
    If the 10.5 mm screw isn’t budging, use some pliers to loosen it
    Joseph Grant - Antwoord
  9. Xbox Series X Power Supply Replacement, Disconnect the fan cable: stap 9, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Disconnect the fan cable: stap 9, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Disconnect the fan cable: stap 9, afbeelding 3 van 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
    But don’t pull the connectors with tweezers because you will inevitably still damage the cable as you have no grip on the connector and the tweezers will slip.
    Leif DeWolf - Antwoord
  10. Xbox Series X Power Supply Replacement, Remove the fan: stap 10, afbeelding 1 van 2 Xbox Series X Power Supply Replacement, Remove the fan: stap 10, afbeelding 2 van 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X Power Supply Replacement, Unlatch the base: stap 11, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Unlatch the base: stap 11, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Unlatch the base: stap 11, afbeelding 3 van 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X Power Supply Replacement, Twist and remove the base: stap 12, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Twist and remove the base: stap 12, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Twist and remove the base: stap 12, afbeelding 3 van 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
    had trouble getting the base off, what worked for me is setting the console on the table sitting on the base and turning the whole console while pushing down.
    techy Waterville - Antwoord
  13. Xbox Series X Power Supply Replacement, Remove the optical drive screws: stap 13, afbeelding 1 van 2 Xbox Series X Power Supply Replacement, Remove the optical drive screws: stap 13, afbeelding 2 van 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X Power Supply Replacement, Remove the vibration isolator: stap 14, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Remove the vibration isolator: stap 14, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Remove the vibration isolator: stap 14, afbeelding 3 van 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X Power Supply Replacement, Disconnect the power and data cables: stap 15, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Disconnect the power and data cables: stap 15, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Disconnect the power and data cables: stap 15, afbeelding 3 van 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
    Once again, DO NOT use tweezers to pull these connectors out. That’s a great way to slip and damage something.
    I managed to get the power connector unplugged, but the data cable just refuses to move. I've used quite a bit of force, and using any more feels like I would damage it. I have no clue on how to get it out safely :(
    Izaac Brånn - Antwoord
    Try to "walk" the connector out: pry up one side, then the other. Best of luck!
    Carsten Frauenheim -
  16. Xbox Series X Power Supply Replacement, Remove the optical drive: stap 16, afbeelding 1 van 2 Xbox Series X Power Supply Replacement, Remove the optical drive: stap 16, afbeelding 2 van 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X Power Supply Replacement, Disconnect the USB port cable: stap 17, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Disconnect the USB port cable: stap 17, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Disconnect the USB port cable: stap 17, afbeelding 3 van 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X Power Supply Replacement: stap 18, afbeelding 1 van 2 Xbox Series X Power Supply Replacement: stap 18, afbeelding 2 van 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
    Connector i-pex Evaflex 5-HD 24 pin
    20952-024e-02
    http://www.i-pex.com/sites/default/files...
    drops206 - Antwoord
    The silver ribbon cable is glued down to the center chassis, so only pulling on the black plastic pull tab will result in it pulling free from the cable as that tab is only glued to the cable.
    Better to heat the silver ribbon cable's adhesive with a hair dryer, separate the cable from the center chassis, and then pull the cable from the connector using the black plastic pull tab.
    Crash - Antwoord
  19. Xbox Series X Power Supply Replacement, Disconnect the power button cable: stap 19, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Disconnect the power button cable: stap 19, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Disconnect the power button cable: stap 19, afbeelding 3 van 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
    I broke this connector during disassembly. Is there a part number I can use to get a replacement on Mouser or Digikey?
    Peter LeCraw - Antwoord
    I broke this connector during disassembly too. Where can I get this connector?
    Oscar Cedeño - Antwoord
    the manufacturer of connectors in series x is I-PEX.  exact part number (as far as I'm not mistaken) 20535-010E-02 EVAFLEX 5-VS.  0.5mm pin spacing (10pin connector). a possible rescue may be to desolder the connector from the switch board and solder it permanently there.
    drops206 - Antwoord
    How do I purchase this from their website?
    munirbisharat12 -
    I have these connectors. Baycroc@fedtel.net
    Evenson Electronics - Antwoord
    Would we be able to order them from you directly
    bailey jackson -
    Yes would we be able to order these connectors directly from you?
    Blake Roan -
    XSX NEXUS FPC Socket
    kasynlife -
    There is no black pull tab on mine😬. How am I supposed to pull it safely?
    Karman Wilmot - Antwoord
  20. Xbox Series X Power Supply Replacement, Remove the chassis screws: stap 20, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X Power Supply Replacement, Peel up the USB port cable: stap 21, afbeelding 1 van 2 Xbox Series X Power Supply Replacement, Peel up the USB port cable: stap 21, afbeelding 2 van 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X Power Supply Replacement, Remove the center chassis assembly: stap 22, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Remove the center chassis assembly: stap 22, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Remove the center chassis assembly: stap 22, afbeelding 3 van 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X Power Supply Replacement, Unlatch the chassis strap: stap 23, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Unlatch the chassis strap: stap 23, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Unlatch the chassis strap: stap 23, afbeelding 3 van 3
    • Unlatch the chassis strap from the right side of the power supply.
  24. Xbox Series X Power Supply Replacement: stap 24, afbeelding 1 van 3 Xbox Series X Power Supply Replacement: stap 24, afbeelding 2 van 3 Xbox Series X Power Supply Replacement: stap 24, afbeelding 3 van 3
    • Pull the chassis strap over and off of the power supply.
    • Once the strap is off of the power supply, set the loose section to the side.
  25. Xbox Series X Power Supply Replacement, Remove the power cable port: stap 25, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm screws
    • One 35 mm screw
  26. Xbox Series X Power Supply Replacement: stap 26, afbeelding 1 van 2 Xbox Series X Power Supply Replacement: stap 26, afbeelding 2 van 2
    • Lift the power connector out of its recess in the chassis.
  27. Xbox Series X Power Supply Replacement, De-route the power cables: stap 27, afbeelding 1 van 2 Xbox Series X Power Supply Replacement, De-route the power cables: stap 27, afbeelding 2 van 2
    • Unlatch and open the lid on the power cable's plastic guide.
  28. Xbox Series X Power Supply Replacement: stap 28, afbeelding 1 van 2 Xbox Series X Power Supply Replacement: stap 28, afbeelding 2 van 2
    • Lift the power cable out from underneath the extra section of the cable guide.
  29. Xbox Series X Power Supply Replacement, Remove the corner cover: stap 29, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
  30. Xbox Series X Power Supply Replacement: stap 30, afbeelding 1 van 2 Xbox Series X Power Supply Replacement: stap 30, afbeelding 2 van 2
    • Your Xbox may not have this cover depending on the model.
    • Use your fingers or a pair of tweezers to lift and remove the power supply corner cover.
  31. Xbox Series X Power Supply Replacement, Remove the accessory antenna board: stap 31, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
  32. Xbox Series X Power Supply Replacement: stap 32, afbeelding 1 van 3 Xbox Series X Power Supply Replacement: stap 32, afbeelding 2 van 3 Xbox Series X Power Supply Replacement: stap 32, afbeelding 3 van 3
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  33. Xbox Series X Power Supply Replacement, Remove the board shield: stap 33, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the nine screws securing the board shield:
    • Six 8.8 mm black screws
    • Two 35 mm silver screws
    • One 13.1 mm silver screw
  34. Xbox Series X Power Supply Replacement: stap 34, afbeelding 1 van 3 Xbox Series X Power Supply Replacement: stap 34, afbeelding 2 van 3 Xbox Series X Power Supply Replacement: stap 34, afbeelding 3 van 3
    • Lift up the board shield to remove it from the center chassis.
  35. Xbox Series X Power Supply Replacement, Remove the chassis strap: stap 35, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Remove the chassis strap: stap 35, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Remove the chassis strap: stap 35, afbeelding 3 van 3
    • Disconnect the chassis strap from the locking tabs on either side of the power supply.
  36. Xbox Series X Power Supply Replacement: stap 36, afbeelding 1 van 2 Xbox Series X Power Supply Replacement: stap 36, afbeelding 2 van 2
    • Remove the chassis strap.
  37. Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: stap 37, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: stap 37, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: stap 37, afbeelding 3 van 3
    • Grip and compress the locking tab on the 10-pin power connector.
    • While compressing the locking tab, lift the connector straight up to disconnect it from the board.
  38. Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: stap 38, afbeelding 1 van 3 Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: stap 38, afbeelding 2 van 3 Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: stap 38, afbeelding 3 van 3
    • Grip and compress the locking tab on the 2-pin power connector.
  39. Xbox Series X Power Supply Replacement, Open the cable guide: stap 39, afbeelding 1 van 2 Xbox Series X Power Supply Replacement, Open the cable guide: stap 39, afbeelding 2 van 2
    • Open the lid on the power supply's plastic cable guide.
  40. Xbox Series X Power Supply Replacement, Remove the power supply screws: stap 40, afbeelding 1 van 2 Xbox Series X Power Supply Replacement, Remove the power supply screws: stap 40, afbeelding 2 van 2
    • Use a T8 Torx driver to remove the four screws securing the power supply around its perimeter:
    • Three 35 mm silver screws
    • One 8.8 mm black screw
  41. Xbox Series X Power Supply Replacement, Remove the power supply: stap 41, afbeelding 1 van 2 Xbox Series X Power Supply Replacement, Remove the power supply: stap 41, afbeelding 2 van 2
    • Remove the power supply.
    Bei meinem Ersatznetz teil musste ich auch die Kunststoff Halterung tauschen, da sonst die Löcher für die Schrauben nicht passten
    Mark Kommnick - Antwoord
    super gute Anleitung
    Andreas Fleischmann - Antwoord
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
26 andere personen hebben deze handleiding voltooid.
Carsten Frauenheim
136.161 Reputatie
371 handleidingen geschreven
iFixit Lid van iFixit
Staff
119 Leden
19.523 handleidingen geschreven
24 opmerkingen
So, I am a skilled DIYer. I had 1 series x that had no power all the sudden, under warranty, sent back and received a refurb. Then I got a halo infinite edition, it all the sudden wouldn't send video. It would power up but I couldn't boot in safe mode or low res mode. Sent it back, send me a refurb. Now my brothers Xbox did the same thing. It turns on but never boots then shuts off after few minutes. No controller connects either, and can't have the xbox sync with the flash. His is not under warranty so I bought a PSU and replaced, still same thing. Any ideas? Microsoft just sends you a refurb and doesn't tell you what was wrong or else I'd know since it happened to my infinite console.
heavychevy9 - Antwoord
Have you tried replacing the SSD drive?
Kason M -
FYI this guide is amazing! Down to providing the length of screws and circling in photos. A++
Well ladies and gentlemen I did it. Took about an hour and a half, only because I put one of the cables on backwards, otherwise it would have only taken an hour. SHES ALIVE!!!! Thank you so much to the person that created these instructions they were SPOT ON!
CAN I GET A A'MEN!!!
Jake Burton - Antwoord
It just worked for me too! Took me about 2 hours, but I tend to work on this stuff extra slowly to be careful. Thanks so much!
Jon Aron - Antwoord
Great guide! It took me about an hour with my 7 year old son helping me. I have PC and laptop background so that helped me a lot about knowing how to remove the ribbon cables and other connections. MS wants $300 to just give you another Xbox. Even with buying the tools I still saved $200. Great job ifixit!
Eric Culler - Antwoord
The hardest thing was that %#*@ base plate,, everything worked great thank you
steven ramey - Antwoord
This guide and the replacement power supply worked perfectly! We got the Xbox Series X when it was first released. In February 2023 it would no longer power on. I took it to two local repair shops and they both said it was too new, they couldn't work on it. Thankfully I found this guide and my 13 year old son and I were able to take it apart and put it back together again ourselves. It did help to have a Torx wrench that you can get some leverage with (L-shaped), especially for the screw with the oversized head. We kept track of the screws by writing the step number on a Post-it Note and sticking each screw on the note with a double-sided adhesive sticker. I wish we would have done this sooner!
Crystal R - Antwoord
My house took a lightning strike 3 months ago and the only two things it fried was my cable modem and Series X. My luck, the Series X's warranty expired about 5 days before that happened. I ordered a PSU from iFixit and just finished installing it. Works like a charm and I'm finally back up and running. I used to build computers when I was younger so the install was pretty straightforward. This was much better than spending $600 on a new system :). Thanks iFixit!
Kason M - Antwoord
Mine just had an issue where it turns on, button lights up white along with a beep, fan spins up for about 5 seconds then stops,
Light stays on but no video feed then shuts off.
Dunno is this is a PSU issue?
I ordered one to be safe, if it still doesn't fix it I will just send it back but if this isn't the issue then what is?
The SSD?
Udon Rodriguez - Antwoord
Hi , I hope you are fine
I have the same problem with my Xbox Series X, for me, when it turns on, after a few minutes of working, a green screen crash suddenly occurs, and as you said, it turns off and then turns on normally. It is not possible and as you said, it is difficult to turn on. Is your problem solved? what have you done?
arshia noor -
Just tried changing the PSU and still wont boot up.
Anyone got any bright ideas?
Out of warranty and qoute from MS is for 400$ to send it in.
Rikard - Antwoord
I recently moved into a new apartment with my wife and my Xbox did not survive the move. While I don't believe the move or packing damaged the power supply, it still did not power up once it was set up in our new apartment. With the LED not even turning on by pressing it, I suspected the power supply. I ordered a new power supply from the iFixit website and followed the repair guide. As soon as I reassembled my Xbox, I powered it on and, to my excitement, it powered on and works!
This was an incredibly helpful and cost effective solution. Thank you for creating this helpful guide!
Stephen Good - Antwoord
very good guide. because of a screw problem, it took me 3 hours. but I'm happy. in fact, for €80 I was able to repair my Xbox where Microsoft was asking me €340, almost the price of a new one.
Thanks to the author of this guide
Rached Cherradi - Antwoord
Guida fantastica, seguita passo per passo il problema è stato risolto! Grazie!
Ugo Petroni - Antwoord
About an hour for me because a ribbon cable tab came off, had to glue it back on. Guide is flawless and it fixed the console. Thanks!
Ian Weston - Antwoord
I’m considering doing this but I’m worried about breaking it in the process. Any idea how risky it is?
Jake Calcutt - Antwoord
It is not risky if you already had experience opening up laptops etc, but if you don't, the biggest risk is breaking some of the cables. (There is really no risk when it comes to screws other than losing them -- make sure to organize your screws well.) And the solution to that is simple -- religiously follow all the instructions here, don't use force to pull something out when it does not come off -- make sure you are always doing the right thing. If anything seems confusing to you, find a Youtube video and follow what they are doing. You'll be ok.
lzps -
Excellent Guide can't go wrong with this. My boy is reborn
Jm10 - Antwoord
I couldn't get the board shield to go back on after I swapped out the power supply. The ten pin power cord seems to be longer than the original.
Chris Conner - Antwoord
These directions were absolutely perfect. Thank you so much. You saved me $220 that Microsoft would have charged me to do the same thing detailed here. My Xbox went from brick to fully functional. Took about an hour of work but the step by step guide with photos was SPOT ON. Cannot be happier.
Farty McGee - Antwoord
Thanks Farty McGee!
Thank you so very much for this guide, I will now order the power supply kit. I thought that I would have to go without for months while I saved enough to have it repaired. Again thanks you have renewed my faith in that there is good people out there. 👍
Dj.Ford - Antwoord
Super tutoriel !
Ma Xbox ne démarrait pas et en changeant l'alimentation elle remarche !!! Merci beaucoup !!
maximeGG29 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 57
Afgelopen 7 dagen: 336
Afgelopen 30 dagen: 1,791
Altijd: 63,278
