Ga door naar hoofdinhoud
VTech CS6719-2 Charging Wire Repair
Wat je nodig hebt
  1. VTech CS6719-2 Charging Wire Repair, Base: stap 1, afbeelding 1 van 2 VTech CS6719-2 Charging Wire Repair, Base: stap 1, afbeelding 2 van 2
    • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
  2. VTech CS6719-2 Charging Wire Repair: stap 2, afbeelding 1 van 1
    • Use the spudger to separate the bottom from the top.
    • There are two clips, located top and bottom, that you have to compress with the spudger.
  3. VTech CS6719-2 Charging Wire Repair, Charging Wire: stap 3, afbeelding 1 van 1
    • Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
  4. VTech CS6719-2 Charging Wire Repair: stap 4, afbeelding 1 van 1
    • Refer to How to Solder and Desolder connections Hoe moet je (de-)solderen?
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very hot.
  5. VTech CS6719-2 Charging Wire Repair: stap 5, afbeelding 1 van 1
    • Heat up solder joint on the base unit where the charging wires are connected.
  6. VTech CS6719-2 Charging Wire Repair: stap 6, afbeelding 1 van 1
    • Take a wire of solder and apply to joint on board to remove the extra solder.
    • Remove charging wire connection.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Josh Showalter
442 Reputatie
3 handleidingen geschreven
IUPUI, Team 1-4, Baechle Spring 2016 Lid van IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 1,460
