Ga door naar hoofdinhoud
Texas Instruments TI-30 XS Multiview Solar Panel Replacement
Wat je nodig hebt
    1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: stap 1, afbeelding 1 van 2 Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: stap 1, afbeelding 2 van 2
      • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
      • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
      • Use the spudger (or fingernail) to pry into the space between the blue back cover and the white body to take off the back cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the battery compartiment: stap 2, afbeelding 1 van 1
      • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
      • Lift the metal plate from the battery and set it to the side.
      Vraag FixBot
      Voeg opmerking toe
    3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Eject the battery: stap 3, afbeelding 1 van 1
      • Use the spudger (or fingernail) to lift the battery from the black holder.
      Vraag FixBot
      Voeg opmerking toe
      • Put the new CR2032 battery in. Never insert a different type of battery!
      • Make sure the positive side of your CR2032 is facing up.
      • Reverse the steps 2 and 1.
      Vraag FixBot
      Voeg opmerking toe
    1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Free the solar panel: stap 5, afbeelding 1 van 1
      • Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
      Vraag FixBot
      Voeg opmerking toe
    2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Carefully pull the panel out: stap 6, afbeelding 1 van 1
      • Be careful not to pull the solar panel too far out, as the wires connecting it to the calculator are fragile and could be ripped off.
      • Carefully pull the solar panel away from the calculator, as shown to the left.
      Vraag FixBot
      Voeg opmerking toe
    3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Unsolder the wires: stap 7, afbeelding 1 van 1
      • The capacitor might not be discharged. Proceed with caution.
      • Unsolder the three wires from the motherboard.
      • Unsoldering help can be found here.
      • To re-solder the wires from the new solar panel to the calculator motherboard take notice of the color and placement of the wires.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Aaron Feinstein
401 Reputatie
1 Handleiding geschreven
Cal Poly, Team 11-2, Forte Fall 2015 Lid van Cal Poly, Team 11-2, Forte Fall 2015
CPSU-FORTE-F15S11G2
4 Leden
12 handleidingen geschreven
1Gids Commentaar
Do you know where I could get a replacement solar panel for the calculator?
Josh - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 42
Altijd: 3,056
