Ga door naar hoofdinhoud
SteelSeries Nimbus+ Controller Battery Replacement
Wat je nodig hebt
  1. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: stap 1, afbeelding 1 van 2 SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: stap 1, afbeelding 2 van 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
    Vraag FixBot
    Voeg opmerking toe
  2. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the sticker: stap 2, afbeelding 1 van 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
    Vraag FixBot
    Voeg opmerking toe
  3. SteelSeries Nimbus+ Controller Battery  Replacement, Unscrew the back cover: stap 3, afbeelding 1 van 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
    Vraag FixBot
    Voeg opmerking toe
  4. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: stap 4, afbeelding 1 van 2 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: stap 4, afbeelding 2 van 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
    Vraag FixBot
    Voeg opmerking toe
  5. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: stap 5, afbeelding 1 van 2 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: stap 5, afbeelding 2 van 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
    Vraag FixBot
    Voeg opmerking toe
  6. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: stap 6, afbeelding 1 van 2 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: stap 6, afbeelding 2 van 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
    Vraag FixBot
    Voeg opmerking toe
  7. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: stap 7, afbeelding 1 van 2 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: stap 7, afbeelding 2 van 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
    Vraag FixBot
    Voeg opmerking toe
  8. SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: stap 8, afbeelding 1 van 3 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: stap 8, afbeelding 2 van 3 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: stap 8, afbeelding 3 van 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
    Vraag FixBot
    Voeg opmerking toe
  9. SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: stap 9, afbeelding 1 van 3 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: stap 9, afbeelding 2 van 3 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
    Vraag FixBot
    Voeg opmerking toe
  10. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the back cover assembly: stap 10, afbeelding 1 van 1
    • Remove the back cover assembly.
    Vraag FixBot
    Voeg opmerking toe
  11. SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: stap 11, afbeelding 1 van 2 SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: stap 11, afbeelding 2 van 2
    • The battery is held in place by mild adhesive.
    • Insert the edge of an opening pick into the gap between the battery and the back cover assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use the opening pick to carefully pry up the battery and loosen the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  12. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the battery: stap 12, afbeelding 1 van 1
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Make sure to align the battery and the back cover of the controller correctly during reassembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
For optimal performance, calibrate your newly installed battery after completing this guide.
Één andere persoon heeft deze handleiding voltooid.
Adriana Zwink
67.546 Reputatie
167 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
26.617 handleidingen geschreven
1Gids Commentaar
Useless directions. The battery has 3 connectors. What is the mode? Where can you buy it? Polarity? If you have one with the right voltage and amps; but has two connectors what's do you do?
All this so-called repair guide says is: "This is how you open the case". Fantastic and then what???
Baldy - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 70
Altijd: 2,326
