Ga door naar hoofdinhoud
Steam Deck Right Thumbstick Replacement
Wat je nodig hebt
Video overzicht
  1. Steam Deck Right Thumbstick Replacement, Prepare your Steam Deck for disassembly: stap 1, afbeelding 1 van 3 Steam Deck Right Thumbstick Replacement, Prepare your Steam Deck for disassembly: stap 1, afbeelding 2 van 3 Steam Deck Right Thumbstick Replacement, Prepare your Steam Deck for disassembly: stap 1, afbeelding 3 van 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck Right Thumbstick Replacement, Remove the back cover screws: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  3. Steam Deck Right Thumbstick Replacement, Unclip the back cover: stap 3, afbeelding 1 van 2 Steam Deck Right Thumbstick Replacement, Unclip the back cover: stap 3, afbeelding 2 van 2
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  4. Steam Deck Right Thumbstick Replacement, Remove the back cover: stap 4, afbeelding 1 van 3 Steam Deck Right Thumbstick Replacement, Remove the back cover: stap 4, afbeelding 2 van 3 Steam Deck Right Thumbstick Replacement, Remove the back cover: stap 4, afbeelding 3 van 3
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  5. Steam Deck Right Thumbstick Replacement, Uncover the hidden shield screw: stap 5, afbeelding 1 van 2 Steam Deck Right Thumbstick Replacement, Uncover the hidden shield screw: stap 5, afbeelding 2 van 2
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  6. Steam Deck Right Thumbstick Replacement, Remove the shield screws: stap 6, afbeelding 1 van 2 Steam Deck Right Thumbstick Replacement, Remove the shield screws: stap 6, afbeelding 2 van 2
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
  7. Steam Deck Right Thumbstick Replacement, Remove the shield: stap 7, afbeelding 1 van 3 Steam Deck Right Thumbstick Replacement, Remove the shield: stap 7, afbeelding 2 van 3 Steam Deck Right Thumbstick Replacement, Remove the shield: stap 7, afbeelding 3 van 3
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
  8. Steam Deck Right Thumbstick Replacement, Disconnect the battery: stap 8, afbeelding 1 van 3 Steam Deck Right Thumbstick Replacement, Disconnect the battery: stap 8, afbeelding 2 van 3 Steam Deck Right Thumbstick Replacement, Disconnect the battery: stap 8, afbeelding 3 van 3
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  9. Steam Deck Right Thumbstick Replacement, Disconnect the right thumbstick cable: stap 9, afbeelding 1 van 3 Steam Deck Right Thumbstick Replacement, Disconnect the right thumbstick cable: stap 9, afbeelding 2 van 3 Steam Deck Right Thumbstick Replacement, Disconnect the right thumbstick cable: stap 9, afbeelding 3 van 3
    • The right thumbstick will be on your left-hand side when working on the Steam Deck, as it's laying upside down.
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
  10. Steam Deck Right Thumbstick Replacement, Remove the thumbstick screws: stap 10, afbeelding 1 van 2 Steam Deck Right Thumbstick Replacement, Remove the thumbstick screws: stap 10, afbeelding 2 van 2
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
  11. Steam Deck Right Thumbstick Replacement, Remove the thumbstick: stap 11, afbeelding 1 van 2 Steam Deck Right Thumbstick Replacement, Remove the thumbstick: stap 11, afbeelding 2 van 2
    • Remove the right thumbstick.
    • Replacement thumbsticks require calibration to work as expected. To calibrate new thumbsticks, follow this calibration guide.
    • Each Steam Deck ships with one of two different models of thumbsticks, Type A or Type B. Although nearly identical, capacitive touch capability relies on the correct type to be installed.
    • To identify which replacement thumbsticks you need, navigate to SettingsSystem and check the Steam Deck Controller ID.
    • If the Controller ID starts with "MEDA" that device needs Type A thumbsticks.
    • If the Controller ID starts with "MHDA" that device needs Type B thumbsticks.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
19 andere personen hebben deze handleiding voltooid.
Carsten Frauenheim
142.937 Reputatie
422 handleidingen geschreven
iFixit Lid van iFixit
Staff
120 Leden
20.224 handleidingen geschreven
3Gids Commentaar
Does this apply to the OLED model as well?
lhflannery - Antwoord
The OLED model's right thumbstick guide can be found here.
Carsten Frauenheim -
I followed this guide and my joystick seems to be fine accept the gyro activation doesn't seem to be working for the new stick. Is there something I should specifically lookout for with the touch support to be seated properly?
Smokey D - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 572
Afgelopen 7 dagen: 737
Afgelopen 30 dagen: 1,499
Altijd: 59,853
